Author Topic: red NGK plug caps RED in the USA?  (Read 7752 times)
Offline xsmooth69x
« on: June 10, 2011, 06:43:05 PM »
i can not for the life of me find red NGK XD05f 8072 spark plug caps
every where i look its all UK sites.
is there anywhere in the USA i can get these or am i just stuck with black?
1975 cb550k
also im replacing the wires on my old coils too. is there any kind of specific wires to look for ?
« Last Edit: June 10, 2011, 06:44:59 PM by xsmooth69x »
1975 CB550 (FINISHED?!?!?)
Offline Hasenkopf
  • Really, I'm not an
  • This space for hire.
Re: red NGK plug caps RED in the USA?
« Reply #1 on: June 10, 2011, 06:51:30 PM »
yeah, another  forum member had them on his bike, and i had asked about them, but I still have no idea where to get them either.
I like berries.
Offline Gordon
  • 750K1, 550K2
« Reply #2 on: June 10, 2011, 07:01:59 PM »
Why can't you order them from the UK?
Offline xsmooth69x
« Reply #3 on: June 10, 2011, 07:05:40 PM »
because im not in the UK.... i would paint the black ones before i pay a huge difference for them coming from the uk
Offline Gordon
  • 750K1, 550K2
« Reply #4 on: June 10, 2011, 07:09:01 PM »
Tell me, exactly what is the price difference between ordering red caps from the UK and black caps from the US?
Offline MoMo
  • Ride like you're invisible
« Reply #5 on: June 10, 2011, 07:10:05 PM »
Is this what you're looking for?  http://www.fastech-racing.com/spark-plug-caps-wires-mounts-etc./  ...Larry
Offline xsmooth69x
« Reply #6 on: June 10, 2011, 07:53:49 PM »
well 3 something pounds compared to $2.50 ish is a huge difference.... and i haven't even checked out the shipping ..........
Offline Gordon
  • 750K1, 550K2
« Reply #7 on: June 10, 2011, 08:28:40 PM »
I wouldn't consider a difference of $9.60 for four plug caps huge, especially for a specific color that you want and for a part that will last a few decades.  And standard shipping from the UK to the US for small parts isn't much more (if any more) than shipping within the states.
Offline xsmooth69x
« Reply #8 on: June 10, 2011, 08:41:14 PM »
u know that is a good point. considering if they last a couple decades.... i didnt know they lasted that long. i decided to go with black caps and red wires.
is there anything big on the wires that go to the coil?
im thinking about either gutting my coils or buying those ngk connector fittings. last owner decided to cut the wires and put them back together with electrical tape  ::)
come to think about it would it be better to just thread the wires together drop some solder onto it and shrink wrap the connection?
Offline Gordon
  • 750K1, 550K2
« Reply #9 on: June 10, 2011, 08:48:05 PM »
If it were me I'd go with the NGK splicers if only for the ease of connection and ability to disconnect if and when needed.
Offline xsmooth69x
« Reply #10 on: June 10, 2011, 09:50:15 PM »
well if they last for decades  ::) but ya do you think the solder would be a better connection or would the splicer be the same. i never used one so i dont know who they connect on the inside.
anything to look for in the wire?
« Reply #11 on: June 10, 2011, 10:51:36 PM »
red ones go faster,i got these from david silvers,,if your worried about postage just buy some more stuff youll use like brake pads and foot peg rubbers or something,this wont up the postage any.
pat english
« Reply #12 on: June 10, 2011, 11:03:49 PM »
hey how do you replace the wires on the coils?just pull them out?i didnt know they came out..
« Reply #13 on: June 10, 2011, 11:10:43 PM »
if you have the stock coils the wires dont come out,and are solid wire,if you have aftermarket go faster coils you can also use go faster leads(wires)of your choice of colour.
pat english
« Reply #14 on: June 10, 2011, 11:17:03 PM »
dang...coils make you go faster?...where do i get some of these aftermarket coils for my cb 750?
« Reply #15 on: June 10, 2011, 11:27:06 PM »
sarcasm,coils do make you go faster if you dont have coils to begin with,if you want to toy with coils and use points,stay with 5 ohm ones.
pat english
« Reply #16 on: June 10, 2011, 11:38:45 PM »
yeah i knew that....i have 2 sets of stock coils but the plug boots have been pulled off.are they still usable?(sorry for highjacking)
« Reply #17 on: June 10, 2011, 11:47:26 PM »
the plug caps screw on to the wire,they have a thread in the wire end,sometimes in the wire end its a bit hashed up,you can trim a little of at a time untill you find fresh wire for the caps to screw back into,this works well compared to buying used coils that have been hacked about or figuring out new coils that dont quite fit etc.,the honda coils last forever mostly,last count was about two million bikes from the 70s still on the factory coils.
pat english
« Reply #18 on: June 10, 2011, 11:53:53 PM »
oh ok..that seems like a poor design..but 2 million bikes..i guess it works...
« Reply #19 on: June 10, 2011, 11:58:24 PM »
2 mill was a lame guess,more like ten mill if you count all the other honda models with fixed high tension wires,its not a poor design at all,no corrosion at the lead to coil insertion point,back in the day it was utter reliability that sold these bikes to a new consumer audience,the last thing they (honda) wanted was a simple ignition failure,i still drive a car with an actuall distributor and i remove the leads once a year from the cap and clean the green build up before it becomes a problem,for the average honda buyer in the era this would be a real pain,like tank off etc,for what its worth ive had high quality spiral wound wire on this car for about ten years,ive had the car for 26 years.
« Last Edit: June 11, 2011, 12:06:07 AM by dave500 »
pat english
« Reply #20 on: June 11, 2011, 12:04:24 AM »
oh i see..i burned out a coil on my sl..it was a 69 though...
« Reply #21 on: June 11, 2011, 12:08:58 AM »
the sl has a different ignition system,it will run without a battery,not the same type of coil.
pat english
« Reply #22 on: June 11, 2011, 12:12:41 AM »
hmmm,mine wouldnt run without a battery..but the battery died alot..maybe it had other problems too..
Offline xsmooth69x
« Reply #23 on: June 11, 2011, 02:06:07 AM »
i know the red ones go faster  >:( thats why i want them!!!
ya i guess ill get a hold of this guy and see what i can do.
from what i understand you can actually hack open the coils and replace the wires from the source then re sealing them.
there are a couple of tutorials about it on the forums.
i just cant for over $$$$ for aftermarket coils.... although it is nice with the fast switch wires and caps....  :(
so regarding the wires..... can i just use any copper core wires? iv also seen wires with build in restricters or something?
Offline xsmooth69x
« Reply #24 on: June 11, 2011, 02:47:39 AM »
USA customers:
Increased security measures implemented by the US gov't mean that airmail parcels are taking up to 5 weeks to arrive. All parcels except the very smallest will be sent by UPS @ 20.00 GBP. Please see the postage guide for more information
yup getting everything state side..... wowow shipping is expensive!!!!!! and all the parts on his site are still more expensive then what is here in the states.....
well black sparkplug caps with red wires then whahahahahaa
