Author Topic: Throttle cable and spark plug wire questions  (Read 1566 times)
Offline zackblack
  • Give my creation... Life!
« on: June 12, 2011, 10:47:32 AM »
Ok so the project is coming along nicely (1972 CB500) but A couple of questions are nagging at me:
1) As you can see in the picture it looks like I should have two throttle cables attached to the carbs.  The Throttle control also looks like it should have two cables (and is missing one).  Can I run as-is or should I get the missing cable?
2) The spark plug wire in the pic is bad.  Can I just replace the wire or do I need to replace the entire coil?
:) If I ask a question and forget to post model and year my bike is a '72 CB500 :)
kaniktshaq moritlkatsio atsuniartoq: Umingmaktormiut dialect.
"Observe the snow. It fornicates."
Offline Nortstudio
  • Not nearly an
  • Just getting started...
    • MotoPreserve
Re: Throttle cable and spark plug wire questions
« Reply #1 on: June 12, 2011, 11:24:54 AM »
You can run without a push cable - but probably not as safely as with one. You just have to make sure you snap your throttle back. Since the bike can use it - it's a fairly cheap fix.
The plug wire can be spliced with a NGK splicer - but only if your damage is a couple inches from the coil. Looks like yours is right on the coil, so you need new coil. You can get used or new - but make sure you read all the threads on getting the correct ohm for your bike.
Good luck!
1976 CB550K...in progress
1975 CL360...eventually custom
2009 Husqvarna TE610
a blog about wrenching in Brooklyn, NY
“Success is dependent on effort.”
~Sophocles
Offline zackblack
« Reply #2 on: June 12, 2011, 11:32:08 AM »
Thanks for the reply -
The wire picture is misleading.  The damage is right at the plug (it pulled apart in my hand when I popped it off of the spark plug).
Offline Nortstudio
  • Not nearly an
    • MotoPreserve
« Reply #3 on: June 12, 2011, 11:44:13 AM »
If it's down by the plug, you may be able to snip a little bit away, as long as you feel it's getting a good connection when you screw it to the cap.
By the way, would not hurt to check the caps, if they are resistance caps (my 550 is, not sure about your 500).  If they are bunk, also not an expensive fix.  And it's one less thing for you to worry about when trying to diagnos issues.
« Last Edit: June 12, 2011, 12:06:15 PM by Nortstudio »
~Sophocles
Offline WarwickE36
« Reply #4 on: June 12, 2011, 11:58:52 AM »
You may have just pulled the cap off of the plugwire.  The cap is a separate piece.  Inside the cap (on the wire side) there is a screw that screws into the wire.  If there is enough length just snip off 3/8-1/2" of the wire and screw the cap back on.  Easy Peasy and FREE!
" Why does anyone get offended by what someone does to their own bike? I dont get it. "
You made me think about it after I cheered knowing someone else would like to know what these control freaks are up to.
 Every time any owner strips whatever precious Honda part the horrified purists parts go up in value. That's not the part that bothers them.
 What bothers them is they sat up late at night, their breast full of wonder and estrogen, unable to sleep, dreaming about their lovely darling and all her glory... and next thing you know someone else doesn't share their emotional deluge and their reaction is they must spread their mind museum as far as they possibly can, taking over as much of the real world as possible.
Drink fast, drive slow, but ride it like you stole it
1974 Cb550 with style
2004 SV650s
Offline zackblack
« Reply #5 on: June 12, 2011, 01:44:47 PM »
Thanks for the reply.  I think it's exactly what I did BUT the inside of the cap where the screw is is dirty and fouled with grease(?) (and so is the tip of the wire) so I think I'll try to clean that up then do the snip off / re-screw and see what happens.
Offline Nortstudio
  • Not nearly an
    • MotoPreserve
« Reply #6 on: June 12, 2011, 02:16:55 PM »
Check the resistance. Nothing like cleaning those up, thinking you've checked them off the list - and then the caps were bad.
~Sophocles
Offline xsmooth69x
« Reply #7 on: June 12, 2011, 03:45:14 PM »
just get some nice new ngk caps.... there not that expensive!! i paid $13 for all 4 of mine
ngk xd05f
^this is for a cb550 but i would imagine its the same for the 500 but please check
1975 CB550 (FINISHED?!?!?)
« Reply #8 on: June 12, 2011, 05:13:33 PM »
Having the second cable really improves your ability to control the throttle with your hand in turns rather than waiting for the spring to react. You will also notice when you reach for the brake lever your palm rolls the grip forward closing the throttle, so the cable would positively close the carb slides.
Offline Ryan66
« Reply #9 on: June 12, 2011, 05:44:37 PM »
Are both the cables the same or are they different part numbers?
1976 CB550k (cafe project)
Offline zackblack
« Reply #10 on: June 12, 2011, 05:47:34 PM »
I was going to ask that very question. :)
Offline underachiever
  • Squandering my potential since 1989
  • 77 CB550K
« Reply #11 on: June 12, 2011, 05:51:37 PM »
They're different. The mounts on the throttle housing end are different and the push cable is a bit shorter.
tony
Offline Ryan66
« Reply #12 on: June 13, 2011, 04:58:29 AM »
So how do we know which one to order? I believe i needs the secondary one
Offline Nortstudio
  • Not nearly an
    • MotoPreserve
« Reply #13 on: June 13, 2011, 05:23:00 AM »
One is called the push cable, one is called the pull cable (and will be labeled that way on eBay or any parts store). If you look inside the control housing, at the throttle, it will be very obvious. Not a bad idea to replace both at the same time - that way you will know they are both fresh.
~Sophocles
Offline Ryan66
« Reply #14 on: June 13, 2011, 09:08:46 AM »
Ya good call i think there like 12.95 a piece. I just saw one on the front of the carbs if sitting on the bike wasnt attached so it may just need reattaching
