Author Topic: Fuel Tank Drain Tube  (Read 698 times)
Offline Spanner 1
Re: Fuel Tank Drain Tube
« Reply #1 on: June 12, 2011, 08:27:28 PM »
Not an air vent just to drain the section of tank under the filler flap which would fill-up with water in wet conditions .... look in there , you will see a drain hole where the hose connects to.... all the 750 F and K7 and 8 'flapper' tanks have it too.
Offline cwchan
« Reply #2 on: June 12, 2011, 08:43:06 PM »
cool thanks
Offline jdubb1977
« Reply #3 on: June 13, 2011, 08:58:00 AM »
...and, if you fill you tank up to high, the extra fuel will run out the tube instead of all over your hot engine.  don't ask me how i know this.  ;)
