Author Topic: has anyone used boyer brandson electronic ignition for sohc hondas?  (Read 1504 times)
amattel
My original plan was to get the dyna s unit, however, since reading that HONDAMAN recommends modifying the stock advance for better performance, I find myself attracted to the idea of an electronic ignition which handles the advance curve internally, as the boyer-brandson unit says it does, based on its monitoring of the engine itself.
does anyone have any expereince with the boyer-brandson units?
thanks,
Adam
kaysystems
Re: has anyone used boyer brandson electronic ignition for sohc hondas?
« Reply #1 on: April 24, 2006, 09:03:01 AM »
Works great for me
David
eldar
« Reply #2 on: April 24, 2006, 11:58:45 AM »
I thought the dyna s used the machanical advance too. I know there was a dyna that did not.
amattel
« Reply #3 on: April 24, 2006, 01:35:58 PM »
Yes. the dyna s does use the mechanical advance.  My thinking was that bypassing it and handling it electronically (as the boyer unit does) would allow timing advance to be more precisely and reliably applied.
eldar
« Reply #4 on: April 24, 2006, 02:59:08 PM »
Ok I misiunderstood. I have thought about it too. The 2 things holding me back is the cost outlay. You have 175 for the unit then new coils and wires and you are looking at about $300 or so. the second is if the processing unit dies, you are screwed. You are stuck and you either hope that warranty kicks in and that you dont wait all summer to get a new unit, or you put you old points back on.
kaysystems
« Reply #5 on: April 26, 2006, 01:55:11 PM »
That's a good thing about the Boyer. It works with stock coils
David
eldar
« Reply #6 on: April 26, 2006, 04:11:38 PM »
They all do but you will not get top performance with the stock coils. I suppose if you are looking to just get rid of points, then I suppose you would be ok.
You can however got new coils for a cb900 on partnmore.com for $26 each. course you need wires yet and those are about $20 on the net.
