Author Topic: 79 CB650 cafe project  (Read 8551 times)
Offline paulh1282
« on: June 14, 2011, 12:51:49 PM »
OK so I bought this bike being "winterized", big mistake. I get the bike home and put oil in the engine and charge the battery. What happens you wonder? Oil pouring from the stator cover and the bike doesnt start. When I pulled off the stator cover i oticed that the rubber grommet had been crushed. After searching for a new grommet and coming up empty handed i ordered a new stator. After installing that and putting more oil in the engine I try to start it up again and the same thing happens. Pulling the cover off again, I noticed that there is a plug that is sticking out of the engine farther than I think that it should be. After hours of looking onn line I determine that the plug is installed backwards. So I turn it around, more oil, and turn the key and wow, no more oil leak. So to the bike not starting issue. I find that the main power cable is grounded to the frame, so I fix that. I then determine that both CDI boxes are burnt up as well. So after ordering those, they are expensive, and installing them I try again. The bike tries to start but still nothing. So I pull the carbs to rebuild and notice that the choke flaps are hitting the carb bodies. So i rebuild the carbs and fix the choke issues. After butting everything back together I turn the key and it starts. Runs a little rough so I dropped it off the get the carbs set correct. Once I get it back I will start the cafe racer convertion. And I am now finding that there are no seat and rear tail sections for this bike so I will be making everything by hand. So keep checking for updates to come.
« Last Edit: June 14, 2011, 01:29:37 PM by paulh1282 »
Offline paulh1282
Re: 70 CB650 cafe project
« Reply #1 on: June 14, 2011, 12:56:59 PM »
Ok so Im having issues posting pictures, anybody have any hints how to make this happen?
Offline MasterChief750
  • Detonation
Re: 79 CB650 cafe project
« Reply #2 on: June 15, 2011, 11:09:38 AM »
Use flickr. And insert.
1976 CB750 K - Drag Bike
I AM THE STIG
Sam is THE STIG
he said i can be STIG3 tho
Offline Bankerdanny
  • Endeavor to persevere
« Reply #3 on: June 15, 2011, 11:14:47 AM »
If you use the attachments option don't forget that there is a maximum file size limit for each picture, plus a aggregate limit if posting mulitiples at the same time.
If the files are too large you won't get an error message, the post just won't work. I have a separate folder set up on my computer where I save pictures in smaller sizes for posting to the board.
Offline paulh1282
« Reply #4 on: June 15, 2011, 12:40:48 PM »
Hope you can see these
Offline paulh1282
« Reply #5 on: June 15, 2011, 12:42:09 PM »
and this one
Offline MikeSlim
« Reply #6 on: June 16, 2011, 10:37:43 AM »
A good friend of mine has a pretty awesome 79 cb650. check out his site chinonthetank.com (a bike blog he runs) and under categories click cb650. He has a lot of great information on there that might be helpful. Im also just about to finish my 80 cb650 which will have a project thread soon.
Your bike looks nice, excited to see the build. Good luck.
Mike
Offline paulh1282
« Reply #7 on: June 21, 2011, 01:11:05 PM »
Ok so my bike is still in the shop and they are saying that they are going to get to it tomorow. We will see... But I had my clubman bars and BMW bar end turn signals in. So here are the pictures of them.
Offline paulh1282
« Reply #8 on: June 21, 2011, 01:34:20 PM »
Lets try this
Offline paulh1282
« Reply #9 on: July 02, 2011, 03:32:20 AM »
So I finally got my bike back from the shop. And of course I couldnt just not work on it already. So I changed my brake master cylinder resivor and started getting the clubman bars on the bike. I am wondering about the clubman bars. Has anybody that used them had an issue with the throttle? After putting everything together and checking, the throttle was really tight. After checking everything I came to the conclution that the paint was put on to thick. So going with this thought I pulled out the 600 grit wet/dry sandpaper. After about an hour of sanding and trying the throttle I got to a place where it works. And being up at 4:30 a.m. and it being around 11:30 p.m. and a half hour drive home I decided to call it a night. Ill try to post some pics...
Offline paulh1282
« Reply #10 on: July 02, 2011, 03:51:03 AM »
OK so the picture resizing thing isn't working for me and I cannot figure out how to get my pictures from flicker to here so if anybody knows how to look somebody up on flicker I am keeping all my pictures there...
Offline paulh1282
« Reply #11 on: July 02, 2011, 04:32:09 PM »
OK today I got the BMW bar end turn signals installed. Still have the wiring to do but at least they are on the bike. Started the bike up to check if anything needed to be adjusted and broke the throttle sleeve, bummer  :( So I just ordered a new one. So it looks like tomorrow I'm going to finish up wiring the turn signals. I have to replace the rear brake light switch so I will do that also. I have new wheel bearing and seals coming along with new fork seals so I will probably just tear everything apart. Was hoping to ride a little tomorrow but that's not going to happen.
Offline paulh1282
« Reply #12 on: July 03, 2011, 04:00:02 PM »
Today was a busy day, 7 hours of working on the bike. I have completely disassembled the front end. Checked the bearing of the staring stem to make sure they were not to messed up. They were good so i pulled them apart and re greased them. I removed the seat and started working on cafe seat. Started by making everything up in cardboard just to make sure what I was thinking would look OK. Then I started Making up the wood framing for everything. Picked up my fiberglass this evening and my foam padding and new vinyl. Cant wait to see what tomorrow brings to get the seat finished...
« Last Edit: July 03, 2011, 04:03:54 PM by paulh1282 »
Offline paulh1282
« Reply #13 on: July 08, 2011, 06:25:45 PM »
Tonight, since I have my daughter and I cant get to the shop to work on the bike, I decided to finish working on the seat. I picked up marine grade padding and vinyl and got to work. This is what I ended up with. I know its not the greatest but its my first time so...
Offline paulh1282
« Reply #14 on: July 08, 2011, 06:26:33 PM »
then this
Offline paulh1282
« Reply #15 on: July 08, 2011, 06:27:33 PM »
and the back
Offline paulh1282
« Reply #16 on: July 09, 2011, 07:44:19 PM »
OK so tonight I replaced the bearings in my front wheel, and replaced the fork seals. Hopefully I can put the front end back together sometime this week and get back to riding. Just a HUGE thank you to everybody that has posted stuff about front forks. They scared the crap out of me but after reading on here about it I had to confidence to give a shot...nothing to it. Again thanks.
Offline Jones
    • "The Jones Special"
« Reply #17 on: July 10, 2011, 08:21:11 PM »
I like the new seat paulh. very nice  8)
1974 CB750 K4
http://forums.sohc4.net/index.php?topic=92252.0
1987 Shelby Charger
1971 Jeep CJ5
Offline paulh1282
« Reply #18 on: July 17, 2011, 04:25:10 AM »
OK got some work done on the bike and its back on the road... I think Im going to take a break from working on it and just ride it until winter. Then do a full break down, powder coat, paint, engine...so on and so on.
Ill take some pictures later and post them.
Offline paulh1282
« Reply #19 on: July 21, 2011, 05:30:52 PM »
OK everybody, I have a question that I hope that somebody can help with. After getting my bike back on the road there were no issues. I found that my new fork seal was leaking so I pulled the bike back apart. while waiting for parts I installed a new rear tail/brake light. Now my oil/stop light stays on. I did some searching and found that if I take off the new light and put the old one back on the light goes off. With the new light hooked up it works correctly. Tail light works, brake light works, license plate light works. The only thing that is different is that the new light is an a fiberglass license plate frame that I made. So can anybody help???
Offline paulh1282
« Reply #20 on: July 28, 2011, 01:32:19 PM »
OK so Im working on my charging system today and notice that there is no 30 amp fuse next to the battery. There is aluminum foil but I want to make it right... Can anybody please point me in a direction as to where I can get one of these from.
Offline paulh1282
« Reply #21 on: July 30, 2011, 12:00:28 PM »
Here is a picture of the bike completed for now. Once it gets cold it will all come apart and do a complete job on it, but I just want to ride while its not freezing...
Offline paulh1282
« Reply #22 on: July 31, 2011, 06:19:15 AM »
So yesterday I hit the interstate and was driving along good. Got to a spot were there was no traffic, and just wanted to get a little speed on the bike to see how it responded. When I hit 85 - 90 mph i got a terrible wobble. I am thinking of putting a steering stabilizer on it. Can anybody help me with the stoke that is required for these bikes and where the best place to purchase one from. Any help is well appreciated.
Offline brycegp
    • 1971 CB750 "Mut-N-Chop" Cafe Project
« Reply #23 on: July 31, 2011, 07:18:04 AM »
A terrible wobble is probably caused by bad bearings...either wheel or steering bearings.  Have you changed them?  I see in your thread you mentioned checking them...
1971 CB750K/F - El Toro
El Toro Build Thread - http://forums.sohc4.net/index.php?topic=73552.0
Offline paulh1282
« Reply #24 on: July 31, 2011, 08:14:39 AM »
Wheel bearings are new, steering bearings looked good so i did clean them up and repack them.
