If you have a stuck slide, take a heat gun to the the carb body, while applying pressure to move the slide. That should free it up for removal. Then clean the slide and the bore with carb cleaner.
You will have to vacuum sync the carbs if you remove slides.
Float height is 22mm. That's in the Carb FAQ.
The Clymer effectively mixes good info with bad info and no info, generally confusing/frustrating new mechanics. I much prefer the Honda Shop manual.
