Author Topic: Oil leaking from exhaust...Help  (Read 1208 times)
newkansan
« on: April 24, 2006, 03:37:21 PM »
Hi everyone
Its been some time since I found this problem, so I cant remember all the details.
For some reason I took off the #4 exhaust pipe.  Something was wrong with that cylinder i cant remember what.
I noticed when i try to start the bike oil spurts out.
I really dont know what the problem is.  can some one help.
I can only imagine that its a bent valve or a tappit ormething of that nature.
But I dont do a lot of engie work so im not sure.
Thanks
rodney
Offline 750goes
  • it will live
Re: Oil leaking from exhaust...Help
« Reply #1 on: April 24, 2006, 03:44:29 PM »
Rodney,
sounds pretty awful, if it's spitting oil out..
take out the #4 spark plug first and report back on its state
try to ikeep smilingĀ  :) :)
Offline Gordon
  • 750K1, 550K2
« Reply #2 on: April 24, 2006, 04:23:25 PM »
First of all (and I know this may sound like a dumb question), but are you absolutely, 100% positive that it's oil and not just condensation turned black by the carbon deposits inside the exhaust?
Offline jph550
« Reply #3 on: April 24, 2006, 04:42:18 PM »
Let's hope its just condensation! If so, you might want to think about replacing the copper crush gasket. then.. no leak
'76 cb550K
with original faded brown/green tank
newkansan
« Reply #4 on: April 24, 2006, 05:06:04 PM »
Oh you are giving me hope.
Ill check for condensation when i get home
It sure looked like oil but i hope its not, now
thanks
newkansan
« Reply #5 on: April 27, 2006, 12:17:40 AM »
Ok,
Checked it out again.  Its not oil.  And I found out why i took off the exhaust in the first place.  It is making a gulping sound.  This time looking for the condensation, I shined a flash light in the hole while I pushed the starter button.  It seems fuel is getting past the valve.  So it was probobally fuel and not oil or condensation.  But I probobally do need a valve job and the gulping sound?? I dont know what that is.
any ideas?
« Reply #6 on: April 27, 2006, 02:36:59 AM »
Check your oil level mate, if you've got a stuck "needle and seat" (fuel valve) in your carb, fuel can pour into your cylinder via an open inlet valve, seep past your piston rings and fill up your crankcase!
Pull your dipstick and check the level, if it looks higher than it should be, and smells of gas, you better dump your oil and filter (including your oil tank) or the fuel will dilute the oil in your engine and transmission, and destroy all therein. Cheers, Terry. ;D
Offline Lumbee
    • My pics...
« Reply #7 on: April 27, 2006, 08:13:43 AM »
When do you hear this "gulping" sound.  When the pipe is off?  If so, that normal...thats just the sound of the piston moving up/down...you don't normally hear it with the pipes on.  If you here it with the pipes on, then you probably have an exhaust leak somewhere...
"I'm not a welder, but I play one on HondaChopper.com"
newkansan
« Reply #8 on: April 27, 2006, 04:50:06 PM »
No I heard the bulping sound with the exhaust on.  So I took it off to see what the sound was comming from.
