Sorry but I have to ask
WHY??
Based on my recent experience in bringing a '77 model back to life:
Q: how can you disable this robust machine for a week or more, using a screwdriver in less than 10 seconds?
Wow - I was asking as a bit of a joke but what great replies - this is what happens when you go to sleep in Australia and wake up the next morning to check your posts...
Ok, so my answer is - grab a screwdriver and remove one of the drain plugs from one of the carbies. If you want to totally disable the bike remove all four. The drain screws are special items, and you can't just plug the holes with M6 bolts because the valve seat is a special taper at the end of the screw. Without these screws the carbies spew fuel, and if you plug the holes any other way fuel floods up inside the carbies and runs into the airbox. Either way you're not getting far without setting yourself alight.
My fun question was in response to me being off the road for a week due to the loss of one of these screws. Of course you can always buy a whole float bowl from Honda, or order the screws from a site in the US - either way you're off the road for a week.
I reckon my answer is a bit getter than some of the ones like smoking the wire harness - now that's a bit drastic!
