Here's my set up:
CB 1000 forks/brakes, 35mm tubes are longer than 550.
Dual piston calipers fit the 550 disks diameter "drilled looks nice"
550 disks are too thick, had to be 4mm from 7mm
CB 1000 calipers are too wide for stk 550 hub w/2.15 alloy rim, spacers/washers needed
I need to get lower triple tree welded up for second bolt in dual brake block.
I need to finish this 20 yr project. Gentleman's Express Gen II
Ricisan
