Author Topic: CB750 dual rotor without speedo?  (Read 2590 times)
NickBee
« on: April 25, 2006, 06:31:08 PM »
Working on the mock-up of my '74 CB750 Cafe racer.  I plan on NOT using a Speedo.  So I guess my question is looking at this diagram how should I proceed.  I'm assuming it would be symmetrical to the side with the rotor on it now.  Use an extra part 10, 20, 2 on the side that the speedo gearbox is on now (where the 2nd disc will be).
Thanks!
Online bwaller
Re: CB750 dual rotor without speedo?
« Reply #1 on: April 25, 2006, 06:56:33 PM »
I suppose#10 is the bearing retainer, 20 is the seal and #2 is the spacer. On the opposite side you won't need these parts. Have a spacer machined the same width as the speedo drive. The bearing on that side will be visible though, so you may want to keep the chrome cover bolted in place or something similar. You may also want to have some little elf ride on your shoulder to tell you when you've speeding!
NickBee
« Reply #2 on: April 25, 2006, 08:02:18 PM »
an elf,, i like that!  I guess my 2 questions are...
1... what not have the same bearing seal on the other side.
2 why go through the troble of getting a spacer machined if I can get the parts off ebay for 10 bucks  (hub with axle and spacers)...
Thanks!
Offline ProTeal55
  • Est1968.com
    • Joe's Barbershop Chicago
« Reply #3 on: April 26, 2006, 06:05:59 AM »
I have a defunct dual-disc setup, and am not running a speedo.
Just had a spacer made up to fill the space where the original speedo drive gear was.
Offline dusterdude
« Reply #4 on: April 26, 2006, 08:17:36 AM »
defunct?
mark
1972 k1 750
1949 fl panhead
1 1/2 gl1100 goldwings
1998 cbr600 f3
Offline volthause
    • gallery
« Reply #5 on: April 26, 2006, 09:18:12 AM »
scott - 1974 CB550
Project Thread - http://forums.sohc4.net/index.php?topic=122740.0
Offline ProTeal55
  • Est1968.com
« Reply #6 on: April 26, 2006, 09:22:05 AM »
NickBee
« Reply #7 on: April 26, 2006, 09:35:09 AM »
Volt,, what size rear tire is that?
Offline volthause
    • gallery
« Reply #8 on: April 26, 2006, 09:59:53 AM »
I'm pretty sure it's a 110/90/18.
scott - 1974 CB550
Online bwaller
« Reply #9 on: April 26, 2006, 01:03:23 PM »
NickBee,
The left side of the hub has a retainer and seal with a short spacer. The bearing on the right side is flush with the outside of the hub and you'll need to machine a spacer the width of the speedo drive to replace it. It will be a custom job, dig-it?
NickBee
« Reply #10 on: April 26, 2006, 08:45:10 PM »
I dig!  But it will have to be the width of a 550 spedo gearbox right (once the disc is on)... Sound right?
mbrock307
« Reply #11 on: April 27, 2006, 04:55:23 AM »
To everyone who is not running a speedo beacuse it is a pain in the ass to set up with a dual disc....  My dad's company can get GPS driven speedometers, no cables, just satellites....  just a thought, it might save u a ticket
NickBee
« Reply #12 on: April 27, 2006, 06:55:52 AM »
LOL, good thought... but this is going to be a cafe... just want the least amount of stuff on it as possible!
Offline Geeto67
  • A grumpy
« Reply #13 on: April 27, 2006, 09:15:20 AM »
Most states require a speedo on a motorcycle, you may not pass inspection without it.
Maintenance Matters Most
NickBee
« Reply #14 on: April 27, 2006, 10:21:19 AM »
this thing will never see an inspection station...
Offline Geeto67
  • A grumpy
« Reply #15 on: April 27, 2006, 11:32:01 AM »
so it it is a race bike?
 I don't know about where you live but you get caught without an inspection sticker in NY the cops have the right to impound the bike (the rarely ever do, most times it is just a slew of tickets).
Your illegal ride aside, for others considering running without a speedo, it is not advisable. Please check with your state as to what equipment you are required to run and how strict your state is about enforcing it.
Online bwaller
« Reply #16 on: April 27, 2006, 05:56:43 PM »
The spacer will need to be the width of the part you remove from your wheel. (Which is the same as the 500 part anyway)
NickBee
« Reply #17 on: April 27, 2006, 08:11:02 PM »
it will be inspected, just not at a NJ DMV.  OK, I will start doing the moch up this weekend.  Thanks for the help...
