Author Topic: Airbox Idea  (Read 743 times)
Offline WarwickE36
Airbox Idea
« on: June 25, 2011, 01:47:03 PM »
I have been following the ANTI-Pod thread and have had a couple thoughts.
First of all Kudos, GREAT WORK!
has anyone ever tried to calculate the airflow restriction of a stock filter/box setup and recreate that in a custom setup that eliminated the box?
My idea at current is to take a MAF sensor from one of my limousine and make an adapter for the CB550 airbox.  This way I could get a gallons of air/second reading at idle, part throttle, and WOT.  Since the town cars ECU also measure throttle position I thought it would keep the test accurate.  Then after constructing a new slimmer airbox I could set it up to the town car and measure readings.  This way I could try and make a custom filter that would retain the same amount of airflow as a stock setup, lessening the need for re-jetting and hopefully allowing for clip position adjustments only (hopeful I know).  I know that velocity stack shape plays a large roll in reducing turbulence and I plan to incorporate them into my design.
Does anyone have any suggestions?
Anyone care to point of some obvious pitfalls to this idea?
Any thoughts are welcome
" Why does anyone get offended by what someone does to their own bike? I dont get it. "
You made me think about it after I cheered knowing someone else would like to know what these control freaks are up to.
 Every time any owner strips whatever precious Honda part the horrified purists parts go up in value. That's not the part that bothers them.
 What bothers them is they sat up late at night, their breast full of wonder and estrogen, unable to sleep, dreaming about their lovely darling and all her glory... and next thing you know someone else doesn't share their emotional deluge and their reaction is they must spread their mind museum as far as they possibly can, taking over as much of the real world as possible.
Drink fast, drive slow, but ride it like you stole it
1974 Cb550 with style
2004 SV650s
Offline coma13
  • Lex Talionis
Re: Airbox Idea
« Reply #1 on: June 25, 2011, 02:16:11 PM »
sounds intriguing!
They wail and weep,
The march of the sheep,
As they go to that cross on the wall.
Offline JohnG
  • 1976 CB750F - original owner
Re: Airbox Idea
« Reply #2 on: June 25, 2011, 03:15:03 PM »
this has probably been written in a number of posts but I'll toss it in anyway.
Back in the late '70s  it was the "hot setup"  to use the air box but make two modifications to it:  remove the lower lip  and drill a bunch of holes in the rear of the lower half.
I had a totally box stock bike at the time.  Doing this mod flowed enough extra air that I had to increase the main jet size from 105 to 115 just to get it to run the same.
the only down side was that the whole unit makes a fair amount of additional noise, long gotten used to.
    John
1971 CB450
1979 CB750F
1982 CB900F
1983 CB1123F - Rick Stetson motor
Offline WarwickE36
Re: Airbox Idea
« Reply #3 on: June 25, 2011, 03:17:05 PM »
Im not looking to increase airflow.
I am looking to make a completely custom setup, similar to Tintops ANTIPOD, but retain stock airflow
2004 SV650s
