Author Topic: Bad starter motor?  (Read 1493 times)
Offline longshanks
Bad starter motor?
« on: June 26, 2011, 01:05:40 AM »
So my electric start on my K6 has been very slow to turn the bike over the last few weeks and I now kick it over instead, happily!  :D
However, its still a nice luxury to have so my first assumption was that the battery was going south so I took it in to Kragen and they put their battery tester on it and it came out fine.(I think around 220 CCA's?) All the other system checks on the battery came out fine as well so I'm pretty sure its not the battery. The problems all started when I tried to start it in 1st gear with the clutch engaged and it came to life fine but since that time it makes an odd noise and cranks slowly and with great effort now. However, if the bike is plenty warm, the electric start will start it after a few slow turns.
So what's the consensus? Bad starter motor? If so, should I just replace it or rebuild? (new brushes, stator, etc.)
cb450 K5
bollingball
Re: Bad starter motor?
« Reply #1 on: June 26, 2011, 04:28:07 AM »
Have you tried jumping the start solenoid?
      Ken
    • http://forums.sohc4.net/index.php?PHPSESSID=jmectsfd9q4d02tcugbr7225a4&/topic,60973.0.html
« Reply #2 on: June 26, 2011, 05:11:54 AM »
if that not helps..open the starter and klean for oil..the komutator must be dry and klean...just vash it in gas..if it are oil"ed...and blow it klean
Offline Spanner 1
« Reply #3 on: June 26, 2011, 05:50:44 PM »
+1 with our Danish buddy........ 'prolly a carboned-op commutator ( where the brushes connect to the rotating part ).
Offline longshanks
« Reply #4 on: December 08, 2011, 12:05:56 PM »
I'm just now getting around to fixing this, once I pull the starter motor I'm expecting the brushes to be worn and "carboned-up" From the diagram below, which brushes are the common ones to go bad? 6 or 7?
cb450 K5
bollingball
« Reply #5 on: December 08, 2011, 12:29:11 PM »
If one is worn the other probably will be too. I would change both :)
                                                   Ken
« Last Edit: December 08, 2011, 12:49:22 PM by bollingball »
Offline Spanner 1
« Reply #6 on: December 08, 2011, 06:12:17 PM »
#6 is the 2 x brushes..... #7 is the brush springs. Rare for brushes to be worn IMO, 'prolly just need to clean-up the commutator and the brush ' faces '  :).
Offline longshanks
« Reply #7 on: December 09, 2011, 12:28:43 AM »
where is the commutator located? is it the surface the brushes rub against?
cb450 K5
« Reply #8 on: December 09, 2011, 04:16:27 AM »
yeps that raund kobber thing the brushes toutch
 normaly it just have to be kleaned..and dryed..
