Author Topic: cb 750 k4 caliper  (Read 694 times)
Offline neil10
cb 750 k4 caliper
« on: June 26, 2011, 11:02:01 PM »
Hi put new pads in  brake won't release
Regreased pivot point, adjusted the screw to adjust still binding
Re: cb 750 k4 caliper
« Reply #1 on: June 27, 2011, 05:27:24 AM »
Did the new pad on the piston side slip in easily with no rubbing or resistance.??  Some of these new pads need to be dressed out a little,sides sanded down,thick paint removed etc. to work properly.  Was it working OK with the old pads before the change.?? Did you remove the piston in the caliper and give the seal groove etc a good cleaning while you were in there.?? If all good down low then you need to check the holes in the master for blockage etc.
« Last Edit: June 28, 2011, 05:36:01 AM by ekpent »
Offline neil10
« Reply #2 on: June 27, 2011, 05:50:45 AM »
 I had good movement in pads free  I have order new seal just in case thats the problem
« Reply #3 on: June 27, 2011, 06:01:27 AM »
Usually the seals can be used again,its the crud that builds up underneath it in the groove.Big question though is was it working before the pad change or is this a rescue ?
Offline neil10
« Reply #4 on: June 27, 2011, 09:36:09 PM »
was working ok
« Reply #5 on: June 28, 2011, 05:43:07 AM »
On a Dodge van I have the caliper would not release once. Turned out to be a collapsed brake line.The fluid - pressure would go forward but not back up the line.Did the rubber hose get bent or manipulated much while you were working on the brakes in such a manner that it could have caused this problem.What was the old fluid looking like in the master when you did this,very dirty and cruddy or fairly clean.May have a blockage in the line somewhere.     Also give the caliper a good whack with a rubber hammer and see if it release.
