Author Topic: HEADLIGHT PROBLEMS  (Read 1866 times)
supersport750f
HEADLIGHT PROBLEMS
« on: May 03, 2005, 02:23:16 PM »
Okay so with all the help from forum members I located a new head lamp at the local Honda dealership. $40.00 . OUCH.
Even with the new head lamp it still doesn't work. Damn.
The turn signals and tail light are working, the fuses are brand new?????????????????????
Any ideas out there? all wires look good?
Anything I am obviously missing?
Offline Dennis
Re: HEADLIGHT PROBLEMS
« Reply #1 on: May 03, 2005, 02:49:04 PM »
Starter button??
Offline Bob Wessner
  • "Carbs Suck!"
« Reply #2 on: May 03, 2005, 02:55:41 PM »
What exactly do you mean when you say the wires 'look' good? How about connectors, might they need cleaning?
StevieMac
« Reply #3 on: May 03, 2005, 03:00:08 PM »
If the wires ar good the fuse is good and the bulb is good then the switch has got to be bugger'd but put the bulb on the battery direct just as a check! don't hold it on the glass they get hot!
I'd run the wires from the light directly to the battery to bypass the switch to see if that works.
