Author Topic: 550 clutch question  (Read 834 times)
Offline fatkid
  • you cant undo whats already been done. so just ask
550 clutch question
« on: June 28, 2011, 04:31:17 PM »
Hey guys got a question I got a 76 cb 550that when running will not go into neutrel . but if not running it shifts fine . i have tried adjusting the cable top and bottom. any input would be great . also it kinda wants to take off when clutch is pulled and you put it in gear.
Offline Gordon
  • 750K1, 550K2
Re: 550 clutch question
« Reply #1 on: June 28, 2011, 04:35:38 PM »
You need to go through the clutch adjustment procedure in the manual to adjust the actual clutch rather than just the cable.
Offline WarwickE36
« Reply #2 on: June 28, 2011, 04:41:55 PM »
I have also noted that oil had a big role to play in this problem.
If the oil is old, not wet clutch approved, or low this problem can occur..
Clutch adjustment too is a big factor as noted by Gordon.
My bike will do this after riding for an hour or so... to and from work (15min.) its never a problem.  I switched to Rotella T synthetic this oil change (still awaiting my cafe seat) I will let you know if this helps my neutral at idle issue.
Lately I have been putting the bike into neutral coming up to stops.  Anticipating stops i go into neutral while still moving, works every time.
Note: I do have some play in my clutch basket, and haven't yet micrometered the clutch discs or plates.
" Why does anyone get offended by what someone does to their own bike? I dont get it. "
You made me think about it after I cheered knowing someone else would like to know what these control freaks are up to.
 Every time any owner strips whatever precious Honda part the horrified purists parts go up in value. That's not the part that bothers them.
 What bothers them is they sat up late at night, their breast full of wonder and estrogen, unable to sleep, dreaming about their lovely darling and all her glory... and next thing you know someone else doesn't share their emotional deluge and their reaction is they must spread their mind museum as far as they possibly can, taking over as much of the real world as possible.
Drink fast, drive slow, but ride it like you stole it
1974 Cb550 with style
2004 SV650s
