Author Topic: Need 550 wiring help  (Read 1126 times)
Offline Bakeoff
« on: June 30, 2011, 06:08:18 PM »
I'm finally at the stage of getting my wiring back on my bike and I'm running into a few issues with where wires go.  Its a 74 cb550.  With the wiring block removed from the bike, I'm cleaning up some of the nasty wires that the previous owner attempted to repair...  As is, I need some help with the following wires:
From the solenoid, I have a large gauge wire that goes to the battery.  There is also a red wire that goes to one of the plugs.  The other has a spade connector on it.  I have no idea where that goes.
At the bottom of the whole unit is a flat little part (regulator?  recitfier?) with one red wire coming off it that also has a spade connector on it.  Do those two connect?
And lastly, on the back there is a clump of wires.  I have a green wire with a 90 degree spade connector on it that isn't connected to anything.
If i could get some help with those three wires, I think I'm about set.  Thanks in advance!
For a guy that has rewired cars from scratch, this is humbling...  Wiring bikes is a whole new deal for me, so knowing what part is what is much different!
Offline Tintop
Re: Need 550 wiring help
« Reply #1 on: June 30, 2011, 06:31:25 PM »
"......For a guy that has rewired cars from scratch, this is humbling...  Wiring bikes is a whole new deal for me, so knowing what part is what is much different!"
I know how you feel, went through the same doing my 550, just think of it as 1/2 a car. ;) ;D  These may help, however the colour one is a later harness, but should be helpful.  Note that there is an un-used ground (green), that sits in behind the electrical panel.
http://data.sohc4.net/CB550.pdf
http://data.sohc4.net/CB550.jpg
1980 CB750F (project)
77 CB550 Cafe build
550/750 Filter Thread
Sidecar Rebuild Thread
Offline Bakeoff
« Reply #2 on: June 30, 2011, 08:35:33 PM »
Well, that takes care of the green wire!  Just have to figure out the other two now!
Offline SohRon
« Reply #3 on: June 30, 2011, 10:54:16 PM »
I guess I'm not exactly sure what you're loking for, but maybe this will help.
« Last Edit: June 30, 2011, 11:00:33 PM by SohRon »
Offline tango911
« Reply #4 on: July 01, 2011, 06:29:20 AM »
CURRENT STABLE:
1969 Honda Dream 305 (black)
1974 Mach III kawi 500 smoker
K2 (project)
K2 Original fixer up
K0 original fixer up
2006 CRF250R
Offline Tintop
« Reply #5 on: July 01, 2011, 06:45:56 AM »
That's the 2nd link I posted above. ;)
77 CB550 Cafe build
Offline tango911
« Reply #6 on: July 01, 2011, 08:05:31 AM »
sorry to steal your thunder Tin Top.   didnt notice that.  :P
CURRENT STABLE:
K2 (project)
2006 CRF250R
Offline Bakeoff
« Reply #7 on: July 01, 2011, 10:24:25 AM »
Seeing that pristine wiring block, I almost want to ditch what I have.  Even after hours of cleaning up old hacks, it barely passes my standards.
Offline tango911
« Reply #8 on: July 01, 2011, 11:51:59 AM »
i like buying new harnesses for my builds. $75 is a drop in the bucket compared to all the hassle and time tracing the hack jobs.
CURRENT STABLE:
K2 (project)
2006 CRF250R
Offline Bakeoff
« Reply #9 on: July 01, 2011, 01:45:56 PM »
The harness itself is in pretty good shape.  Like I mentioned in my email, if you have the wiring block or whatever the heck its called, i'm in!  I want to ditch the pile I have!  i'm also going to look at a parts bike this weekend.  Does anyone know if the wiring for a 76 is the same as a 74?
