Tews,
The luggage is aftermarket, pull it off and you will see a great bike! Don't misunderstand Bryan when he says parts don't exist. He means you may not be able to buy them new from Honda, but good used parts are readily available and reasonably priced.
He probably replaced the points w/electronic ignition, a good thing. Yes, that frame is basically the same as the other bike you looked at.
If it has a title and can be had for around $1200 or less, I'd say it's a good buy.
Go see it in person ASAP!
