Author Topic: How does my bike sound to you?  (Read 710 times)
Offline tydeus
« on: July 12, 2011, 10:34:41 AM »
This is my 1977 CB750K. New points/condensers, new plugs, new Dynacoils, new spark plug wires. It's always had a bad stumble off of idle but it seems better after I updated the ignition system.
Here's a short vid:
1977 Honda CB750k
All four pipes are getting hot, it just seems to stumble here and there. I'm not sure HOW its supposed to sound. I know it's a 34 year old bike so maybe my expectations are too high?
Offline crackerbat
Re: How does my bike sound to you?
« Reply #1 on: July 12, 2011, 03:27:57 PM »
sounds just like mine
Offline KRONUS0100
  • MAD MATT THE MANIAC
« Reply #2 on: July 12, 2011, 05:21:20 PM »
sounds like mine, same rattle from clutch area an all.
MATT
« Reply #3 on: July 12, 2011, 05:48:02 PM »
Stock airbox? Clean air filter??
Sounds pretty good, all 16 seconds! Have you sync'd the carbs?
Offline tydeus
« Reply #4 on: July 12, 2011, 08:14:55 PM »
Well I guess I should have recorded a longer vid. I have not synced the carbs yet. What's the agreed upon best sync tool for the job? I assume it's easier than the valve adjustment.
Also, thanks for confirming that the bike sounds fine!
Offline Johnny5
    • CB350F build thread
« Reply #5 on: July 13, 2011, 04:43:42 PM »
To me, it sounds like your timing might be a tad off, but other than that it sounds okay. I can hear the valves ticking away which means they're not tight.
www.kerosenecycles.com
1971 CB350
1973 CB350F
2006 Harley Springer Classic
