Pinhead, I time from the secondary. Always have and as you said, both systems fire the same, which is what I was getting at.
It does not matter when the trigger is made(aside from dwell times for saturation of course)what matters is when the spark fires. It actually does not even matter the supposed advance of the ignition, what matter is if things fire when the mechanical marks indicate they should. No matter the system, if you time via secondary, which I believe one should always do, if you are on the correct marks, then your advance is fine.
This is pretty simple stuff, really.
Spanner, Dont you thing the unit is made to compensate for its faster response time? I mean that is the whole basis of your argument. "oh the electronic fires faster so therefore, even if marks line up, somehow, magically, your advance is wrong."
This is not the case.
All that matters is that spark happens when it is supposed to. And it does. The rest of us have all seen this. The ignitions are made to work within the parameters of the bike, just more accurately.
