Author Topic: Help - Missing Bolt On Brake Bracket - CB550!  (Read 2139 times)
Offline volthause
    • gallery
« on: April 29, 2006, 03:46:51 PM »
While totally overhauling my front brake today, I noticed a hole that looked like it was supposed to have a bolt there, but it appears to be missing.
Please see attached photo.
Can anyone tell me what size bolt it is? I tried I few I had laying around, but none of them would thread in there very far.
Thanks in advance!
scott - 1974 CB550
Project Thread - http://forums.sohc4.net/index.php?topic=122740.0
Offline mcpuffett
Re: Help - Missing Bolt On Brake Bracket - CB550!
« Reply #1 on: April 29, 2006, 03:51:56 PM »
i would say 10mm /12mm or 13mm  :-\, but if you can check nothing snapped off in there already  ;)  mick.
Offline seaweb11
  • 1st Mate &
  • Ride & Smile
    • Playground Directory
« Reply #2 on: April 29, 2006, 04:46:27 PM »
That's for the rain cover/fender widget over the break disc.
Offline volthause
    • gallery
« Reply #3 on: April 29, 2006, 05:04:21 PM »
I did check to see if the hole was clear, and there isn't anything that I could tell that had snapped off in the hole.
So the rain thingy is attached there? I would guess  that the bold holding that on also helps hold the caliper bracket on the fork though, right?
scott - 1974 CB550
Offline Chris Liston
« Reply #4 on: April 29, 2006, 05:57:22 PM »
Yes, that is the lower caliper bracket bolt.  I wouldn't ride until you get it replaced.  Just to be safe
1976 CB550F Cafe in progress
Offline cben750f0
« Reply #5 on: April 29, 2006, 08:45:49 PM »
thats the main caliper arm bolt.... !!!!! dont ride that until its replaces, otherwise you are expecting 2 M6 blots to stop 250kg!!! not good, the bolt is an M8 X 35mm hope this helps...peace
Offline volthause
    • gallery
« Reply #6 on: April 30, 2006, 01:04:30 PM »
Thanks for the replies. I went to the hardware store and got a bolt. Glad I found that it was missing! Sounds pretty unsafe without it.
scott - 1974 CB550
