Author Topic: Dealing with stretched carb bowl gaskets.  (Read 14605 times)
Offline Duanob
  • Bold Timer
  • Gotcha!
« on: July 16, 2011, 04:44:58 PM »
Found a decent trick that worked for me. My bowl gasket o-rings were getting stretched beyond use. All the glue in the world won't hold them in place anymore.
Install the o-ring gasket in the groove all the way around the bowl. When you get to the point of the extra that won't lay smooth, cut it. LAy one end in the groove, lay the other over it and cut to fit. Do this in a straight stretch of the bowl. Then take some Permatex Type 2 gasket sealer (it's pliable and fuel resistant) and dab it in the cut area and install it on the carb body. Let it set for an hour before letting gas into the bowl. I haven't seen on of these fixes leak yet. Eventually you will buy new ones but this fix will get you on the road while waiting for the new one to come in and the fix will last you until you absolutely nessecarily need to open the bowls up again.
1974 CB360T
1976 CB550K2 Resurrected
1976 CB550F2 Barn Find
1979 CX500 VG "HONDA-GUZZI"
2007 Moto Guzzi Breva 750ie
2015 BMW F700GS
Another 1976 CB550K Cafe?
  __o
_- \_<,
Offline lucky
Re: Dealing with stretched carb bowl gaskets.
« Reply #1 on: January 07, 2012, 09:23:07 AM »
DO NOT DO THIS people!!!
It can lead to a fire. Very bad advice!!
Do not remove the float bowl O ring in the first place unless you know it is leaking.
If you spray the O ring with carb spray (trichlorethyelene), the O ring will swell up and never fit right again.
Float bowl O rings almost NEVER go bad.
Just smear a little Vasoline on the float bowl with O ring when you put the float bowl on.
You do not need to replace the float bowl O ring just because you took the float bowl off.
Offline jezland
« Reply #2 on: September 22, 2016, 02:30:32 PM »
I'll second the DO NOT CUT sentiment.
If the O-ring gaskets are stretched out and do not fit, check out this thread: http://forums.sohc4.net/index.php?topic=32651.0
I can vouch personally that I has success with the boiling water (helps remove the soaked-in gas; you'll smell it) and then pop them in the toaster oven on low for 10 minutes. Fit like new after that.
'76 CB550K
Offline alienlifeform
« Reply #3 on: August 25, 2020, 12:30:00 PM »
I can ALSO vouch personally that the "soak in boiling water and then pop them in the toaster oven on low for 10 minutes" technique works. Amazing.
Offline madmtnmotors
  • When did I get to be a
  • Sunny Central Florida
« Reply #4 on: August 26, 2020, 04:01:42 AM »
Wow, this is one slow motion zombie thread. Took six months for the second post, four years for the third post, and another four years for the fourth post.
I'll be sure to check back in another four or five years...  ::)  ;D
TAMTF...
Wilbur
Projects:
Sent from my Tandy TRS-80!
« Reply #5 on: August 26, 2020, 04:24:55 AM »
It happens because people do not read the post dates. I've seen it lots on multiple forums. They don't read through the replies before posting a reply.....
Offline Redline it
  • thread killer
« Reply #6 on: October 06, 2020, 01:43:45 PM »
i found a pretty good solution couple weeks ago and still holding out. well the holding out will be known in under 5 mins after application. i have orings that have been running for a year now. i had to take bowls off because of gas leaks the whole year, i thought the inlet needles were all bad but the gas leak would form around all bowl joints where the orings go into. my bowl joints are all slighty bowed from over tightening oversized orings in the past, you can't bend them back either, bodies and bowls will have a gap. but onto the fix of reinstalling the "expanded" oring into the groves:
Place as much oring into a straight leg of the groove, clean and dry groves and orings are important, now take a piece of straight masking tap and only cover the oring to its edge with the clean straight edge of the tape, then feed the oring into the next straight leg, and with another straight cut of tape cover the oring just to it's inner edge, the last 2 legs start to push or cram more oring in and tape. once it's in, hold with your palm, and push the screws through and without scratching the bowl mating surface on inner side of the screw you'll want a tear in the tape for easier extraction. all around the bowl you should have tape extending out, you don't want to tape it to the sides of the bowl. mount the bowl and snug it flat to the body, when they are all in, turn the gas on, you shouldn't have any leaks, when the bowls are full shut the gas off and loosen the bowl evenly only enough so the tape will then slip out and not the oring.  the tape, it'll come right out unless you didn't cut the tape or tear it. then youll have to wiggle it back and forth to get the tape to come out around the corners.  it takes only a slight bit of a second to do the taping. it wont work for shrunken orings because there's no lip on the inside of the bowl groove. don't use any types of hardening glue like crazy glue in the corners, it'll work but then you'l be more prone to "cleaning the groove," that's when you'll possibly scratch the groove. you don't want to use anything harder than the metal it's made out of to clean it, and if it's dirty even plastic can scratch it. no scratches in the groove. don't use oversized diameter orings, unless everything is trashed. that sealing joint is designed to compress the oring so the groove will just be filled with the oring at the point the 2 "flat" mating surfaces come together. there's not alot room for errors nor scratches. slightly over sized diameter orings will bend the corners on the bodies and the bowls. if you tried to bend them back they'd break.
