Author Topic: The Abomination thread!  (Read 497277 times)
Re: The Abomination thread!
« Reply #2650 on: March 29, 2022, 01:21:46 PM »
They use a weird paint job like that...
It may be vinyl wrap?
« Reply #2651 on: March 29, 2022, 02:32:15 PM »
They have “rust bucket” vinyl wraps for new vehicles, they look very authentic from a distance.
Offline spotty
« Reply #2652 on: March 29, 2022, 02:39:57 PM »
i did a rust paint job on one of my helmets that was reaching the end of its life, i even used araldite glue to make the bubbling around the edges that you get as rust blows out metal, looked most convincing
i blame Terry
Offline Bankerdanny
  • Endeavor to persevere
« Reply #2653 on: March 31, 2022, 03:00:30 PM »
Offline Bankerdanny
« Reply #2654 on: March 31, 2022, 03:02:00 PM »
They also used the Rover V8 in the MGB/GT. They were used for police cars. All of the MGB's were made to bolt in the Rover V8.
Only the 75 and later cars with the rubber bumpers were made to fit the V8, to install one into a chrome bumper MG takes a bit more work.
Offline Bankerdanny
« Reply #2655 on: March 31, 2022, 03:03:18 PM »
That's my understanding too, since the rubber bumpers began to appear they were V8 ready. Chrome bumpered models required a long list of mods to make them V8 ready.
It's not too hard, when I was in the MG Car Club there were quite a few chrome bumper cars with the Rover V8 and some 302 Fords with aluminium heads and intake manifold. Another motor that is easy to install is the GM 60° V6. The 2.8L/3.1L/3.4L series V6 motors weigh within 20lbs of the stock 1.8L four cylinder. A stock 3.4L V6 makes 180hp, I have built my 110hp 2.8L V6 up to 240hp which is a nice output for an MGB. Currently I am building twin 10 to 1 compression MG motors with ported heads and lightened rods for our two MGB GT's.
I have been planning a 2.8 swap into my '72 BGT for a while now. I have the engine and a T5, but still need the swap kit and the time to actually do it.
Offline Kelly E
  • Geriatric Hooligan
« Reply #2656 on: March 31, 2022, 05:27:31 PM »
I used 3.4L heads and crank to build my 2.8L block. The 3.4L heads have bigger valves and mine are ported and polished with 1.6 roller tip rockers. The block is .030" over and clearanced for the 3.4L crank that has more stroke. I used a double row timing chain and assembled it with ARP studs for the heads and crank. On top is an Edelbrock aluminium intake, a Holley 390cfm four barrel carb and a custom curved rebushed stock distributor.
I built the motor to run hard and have been beating on it for 18 years. I can't say enough good about the ARP studs. I broke the first crank and all I had to replace was the crank and I replaced the bearings just because. The studs held it all together so nothing got tore up. The last thing I broke was the clutch last fall. On a hard 3rd to 4th shift I blew the center out of the clutch disc. That's hot rodding for you. One of the good things is I still get 16mpg when I beat on it. Big blocks that get 6mpg don't cut it anymore. 8)
1978 Kawasaki KL 250
1980 Suzuki GS 1100E
1983 Honda CB 1100F
1984 Honda VF 700S Sabre
1990 Moto Guzzi 1000 Le Mans
2005 Harley Davidson Fat Boy
Offline Bankerdanny
« Reply #2657 on: April 06, 2022, 01:24:29 PM »
My engine is the port injected 2.8 from a Fiero, rated at about 14o-145hp net vs the stock MG that was supposedly 95hp gross. Supposedly under 90k miles. The guy I bought it from swapped a supercharged 3.8 into his car.
I want to retain the original FI, I love the Fiero manifold look and I got the full harness and computer, but I am told there is an issue with the throttle body clearance to the bonnet with that intake. I just found a 3.4 Camaro at the local LKQ and I really should go grab the intake and throttle body and some other parts just in case.
I have to relocate the starter too since the Fiero engine is transverse and the starter is on the left side of the engine but the RWD version has the starter on the right side. Fortunately there is a kit to do the reverse relocation right to left, which should also work for what I need.
Offline faux fiddy
  • bike in a box
« Reply #2658 on: April 16, 2022, 03:42:24 AM »
C'mon now, this is an abomination thread. There hasn't been a single new :o abomination in three pages.
I think this type of abomination happens because the side covers are so hard to find. ::) ??? I'll prolly wait and see what you guys are disturbed by  here.  But if you love this magnificent expression of moto-artistic license in teal and shades of cinnamon, lucky you. It is available for the bargain price of $12,500 U.S.D.
https://www.facebook.com/commerce/products/1973-honda-cb/4296960510407210?ref=messenger_share&rt=54
« Last Edit: April 16, 2022, 04:13:15 AM by faux fiddy »
^^^^^^^/l^^^^^^^^^^^^^^/l^^^
Offline Alan F.
« Reply #2659 on: April 16, 2022, 07:54:28 AM »
Ok, has this been posted?
« Last Edit: April 17, 2022, 08:47:01 AM by Alan F. »
« Reply #2660 on: April 16, 2022, 08:03:48 AM »
The 350f is a true abomination of gaudiness
The Harley is another idea that didn't need to be expressed. Just because I can think something up does not mean I should build it.
Funny stuff
Offline Ichiban 4
  • "Ichi"
« Reply #2661 on: April 16, 2022, 10:02:31 AM »
Yeah..the 350 reminded me of some of the custom bike stuff we saw back in the 50's and 60's..
Maybe because a lot of us were relatively poor (right after WWII and Korean War..some coming out of depression years of 30's) and wanted to be 'creative' when rebuilding/restoring old bikes LOL
Looked to me like the fellow restoring the 350 had access to a lot of various anodizing and spiral-metal finishing methods..that he used to 'dress-up' that bike.  So probably wasn't as financially limited as the old-timers were years ago.
But one thing that came to mind seeing that..was that some of us tend to get so caught-up in the work and methods we're using at the time..that we aren't thinking about what it will turn-out to be/look like as a finished product.  Personally feel that's okay..but can't expect that others will necessarily appreciate "all the work you put into a project" LOL
The $12K asking price on that seems to indicate that the seller thinks it's worth all the time and money he put-in to it..which of course it isn't to most people..but as others here have indicated..worth a few chuckles to look at..
Al/Ichi
Al Summers
Present: '77 550K
« Reply #2662 on: April 16, 2022, 02:49:31 PM »
Yes, the old “too much to list” syndrome, meaning it’s a bunch of parts put together with little regard for functionality or look.
« Reply #2663 on: April 17, 2022, 12:47:17 AM »
I restored a CB350F back in 1996 before Ebay etc, when I had to buy all NOS parts from my local Honda dealer. It was a $200 swap meet pile when I bought it, so I needed everything rechromed, rebuilt, repainted (professionally) powder coated etc etc. All up it cost me $3900 AUD ($2500 USD) but I did catch a break on a complete NOS exhausts system ($600) and NOS seat. ($400)
Looking at the "Abomination" 350F I can't see how there's anywhere near $12500 in it. The walkaround was accompanied by the sound of crickets, and I think that's all he's gonna hear while waiting for some cool hipster type with deep pockets to fall in love with it, and pony up the dough.... I don't want to even mention the "Scootster", it defies any form of logic ;D
Offline faux fiddy
  • bike in a box
« Reply #2664 on: April 17, 2022, 08:38:08 AM »
Yeah, I'm thinking there's a fair bit of money in cheap  rattle can paint considering the dollar cans are a thing of the past, but carbs look (and likely will perform) better soda blasted. The gold spray-on rebuild  is not my favorite color, and unless it's black it impedes dissipation of heat.  And it will all look like crap within 1,000 miles running at operating temp. ( I don't see this guy putting any significant miles on the bike for obvious reason is he is selling it as a runner without new issues popping up. )  As for the tank, the stock 350 f tank has nice lines, and slight knee dents.  It is hard to figure how anyone, adding new paint/graphics which are completely different, and laid over the stock contours of the tank,  somehow can think it will  look better. Then inspect the difference in the gages- this bike is cobbled out of used parts of different quality.  What is going on with those pipes? Are the middle ones just straight hanging/hiding under there? Beautiful stock bikes sell for about 1/3 of that regularly if not much less.
Offline faux fiddy
  • bike in a box
« Reply #2665 on: April 17, 2022, 05:37:36 PM »
The Vetter scooter I can live with looking at and not want to pluck my eyeballs out.  Vetter would be the one to raise the bar.
https://1.bp.blogspot.com/-fdNB7nrNrww/Xv1tfsGCTcI/AAAAAAAAeu8/CpT2ZKQjkuoUUihIbllKrwpsoSPeLRLEQCLcBGAsYHQ/s1600/2004-Vetter%2BTorpedo-1.jpg
« Last Edit: April 17, 2022, 05:40:46 PM by faux fiddy »
« Reply #2666 on: April 17, 2022, 06:44:24 PM »
Yep, I'm a Harley fan and own a couple of Sporties, and as horrible as it is to see one turned into a scooter, the Vetter one doesn't look disgusting. I'd be fascinated to see how one went around corners though, there's a lot of bike behind the rider, and not much in front..... ;D
Offline simon#42
  • liverpool
« Reply #2667 on: April 18, 2022, 02:06:06 AM »
also interesting to see how they kept it cool . buell had enough trouble with the rear cylinder overheating in the ally framed bikes . a fully inclosed air cooled v twin looks like a very bad idea . not the worst looking bike in this thread though .
« Reply #2668 on: April 18, 2022, 07:58:55 AM »
Really strange
Offline Alan F.
« Reply #2669 on: April 18, 2022, 10:00:48 AM »
After looking fruitlessly for more info I looked at all of the available pictures closely and it looks to me that the large black circles on each side are electric fans. I'm not sure if it would be cross-flow or both directed inward or outward, but I'm sure that rear cylinder is getting its share of the wind.
Edit, I think they're intake fans. Notice the 'portholes' at the rear are filled with the same old 'pop-vents' that were used on his fairing windshields.
« Last Edit: April 18, 2022, 10:03:37 AM by Alan F. »
« Reply #2670 on: April 18, 2022, 12:05:54 PM »
Yeah, I thought the same thing Alan. I remember my mate Davey had an overheated rear cylinder on his ‘79 AMF Sporty, and probably why my ‘73 Iron Head Sporty has a massive oil cooler. ;D
Offline Just John
  • Apparently I am a glutton for punishment
« Reply #2671 on: April 18, 2022, 01:39:59 PM »
The Evo Sportster engine should (in theory) run cooler than the old Ironheads.  But, I would still run an oil cooler on an Evo engine especially in the warmer climates.  In the 70s I used a Ford power steering cooler on my bikes and never had any problems.  I have an old NOS cooler for my 79 XLS if and when I get it ready to ride.  Vetter based his scooter concept on Tony Foale's "feet forward design"
Member
AMA Charter Life Member
AMCA
VJMCA
« Reply #2672 on: April 18, 2022, 02:29:22 PM »
Thanks mate, I’ve also got an Evo Sporty, a 1994 XLH1200 and have never had any issues with overheating, but when I eventually install the Hammer Performance 1275 kit, “Buell” heads, 570 cams etc I’ll install one as cheap insurance. I used to make oil cooler kits for CB750’s and recently found a box full of new US made power steering cooler rads so I’m in the process of installing one on my 1975 Kawasaki Z1-B hotrod, and I’ll put one aside for my Evo Sporty as well. ;D
« Last Edit: April 18, 2022, 02:35:19 PM by Terry in Australia »
Offline faux fiddy
  • bike in a box
« Reply #2673 on: April 19, 2022, 05:04:11 AM »
The bike is just over thirty miles away and I would go see it, but the peril of possibly meeting a total douchenozzle is not worth it.
Offline faux fiddy
  • bike in a box
« Reply #2674 on: April 19, 2022, 05:09:12 AM »
Yeah, the more professional keep simple thing as if it's a rule. Start with the silver trim that wraps around it is all the same line front to back.
