Author Topic: Is my coil wire bad?  (Read 1076 times)
Offline zackblack
  • Give my creation... Life!
« on: July 19, 2011, 07:15:07 AM »
Ok first: '72 CB500
One of the wires coming off of my coil will not screw tightly into the cap.  I've clipped 1/2" off the end of the wire and tried again but I have the same problem.  The core is twisted copper wire but seems to have squishy black tar-like stuff in it around the wire and between the wire and the insulation cover.  I suspect the wire is in this condition all the way up to the coil.
Is the coil wire bad?  Is the coil bad?
I haven't tried to turn it over yet (i still have to replace the fouled plugs).
:) If I ask a question and forget to post model and year my bike is a '72 CB500 :)
kaniktshaq moritlkatsio atsuniartoq: Umingmaktormiut dialect.
"Observe the snow. It fornicates."
Offline DJ_AX
Re: Is my coil wire bad?
« Reply #1 on: July 19, 2011, 07:51:06 AM »
I have a couple of wires like that on my 550. I'm surprised that they work but they do. I plan on replacing them soon. I'm sure they're likely to fail eventually.
Offline WarwickE36
« Reply #2 on: July 19, 2011, 08:12:22 AM »
I had 1 like that, it was too short to cut.  I replaced my coils with Dyna coils and got replaceable plug wires.  400 miles on them so far with zero complaints.
" Why does anyone get offended by what someone does to their own bike? I dont get it. "
You made me think about it after I cheered knowing someone else would like to know what these control freaks are up to.
 Every time any owner strips whatever precious Honda part the horrified purists parts go up in value. That's not the part that bothers them.
 What bothers them is they sat up late at night, their breast full of wonder and estrogen, unable to sleep, dreaming about their lovely darling and all her glory... and next thing you know someone else doesn't share their emotional deluge and their reaction is they must spread their mind museum as far as they possibly can, taking over as much of the real world as possible.
Drink fast, drive slow, but ride it like you stole it
1974 Cb550 with style
2004 SV650s
Offline Nortstudio
  • Not nearly an
  • Just getting started...
    • MotoPreserve
« Reply #3 on: July 21, 2011, 10:31:17 PM »
NGK makes splicers that allow you to cut the original wire close to the coil, and put new wires on to the end, for a fresh connection to the plug caps.  Cheaper than new coils, if hats a concern.
1976 CB550K...in progress
1975 CL360...eventually custom
2009 Husqvarna TE610
a blog about wrenching in Brooklyn, NY
“Success is dependent on effort.”
~Sophocles
« Reply #4 on: July 21, 2011, 10:43:18 PM »
Um, probably not.  The tar stuff is the insulation damage by arcing at the poor connections.  Sounds like yours were loose for quite a long time.
NGK makes splicers if you can't cut back enough to make a solid contact AND reach the spark plug.  Splice in stranded copper core ignition wire if that becomes necessary.
Wire insulation is bad wherever it is goey.  The coil itself is probably NOT bad.
Replace if you can't find better uses for your money.
« Reply #5 on: July 22, 2011, 12:17:29 AM »
you might blast some carb cleaner or similar into the opening,then blast it out with compressed air,then squish around and compress the end of the wire with pliers a little,then try and re thread on your cap.
