Author Topic: '72 CB450 Front Brake Light Switch Not Working??  (Read 3406 times)
Offline dylboss
« on: July 19, 2011, 05:26:22 PM »
I'm trying to figure out why my front brake light switch just cut out.  Been fixing/bleeding the front brakes lately, and now I noticed that the switch isn't working.  I don't see any electricals going to the lever, so I'm a bit confused on how this gets triggered.  Anybody know what I might be up against?
Thanks.
Current
- 1972 CB750 K2 - Brier Brown Metallic
- 1973 CB750 K3 - Flake Sunrise Orange
- 1974 CB750 K4 - Flake Sunrise Orange
- 1976 CB750 K6 - Candy Antares Red
Previous
- 1978 Honda CB550K
- 1972 Honda CL350 Scrambler
- 1972 Honda CB450
- 1998 Suzuki TL1000R
- 1993 Yamaha FZR 600
Offline tbpmusic
Re: '72 CB450 Front Brake Light Switch Not Working??
« Reply #1 on: July 19, 2011, 06:42:33 PM »
The "switch" is actually attached to the lower triple clamp - the 450 has a two piece brake line, one end of each piece goes to this switch.
Two wires go to the switch.
Bill Lane
Offline dylboss
« Reply #2 on: July 19, 2011, 06:47:31 PM »
Thanks.  Eventually found this, but how does this switch actually work?  I'm guessing it is on pressure with some sort of plunger?  Is there a dedicated fuse for the rear brake light?
Current
Previous
- 1978 Honda CB550K
- 1972 Honda CB450
Offline MoMo
  • Ride like you're invisible
« Reply #3 on: July 19, 2011, 07:08:16 PM »
Pressure activated, put your ohmmeter across the two posts then pull brake lever and see if you get continuity...Larry
Offline dylboss
« Reply #4 on: July 19, 2011, 07:18:19 PM »
Thanks.  Gonna swap it out with another one from my other bikes that works and test.
Current
Previous
- 1978 Honda CB550K
- 1972 Honda CB450
« Reply #5 on: July 19, 2011, 07:36:32 PM »
Be careful when you take it out. Brake fluid everywhere.  If you don't plug it quick it can drain your entire top line.
Offline MoMo
« Reply #6 on: July 19, 2011, 07:47:36 PM »
No need to swap it out, check first with an ohmmeter to determine if it is bad....Larry
Offline dylboss
« Reply #7 on: July 20, 2011, 08:53:53 AM »
Swapped it out, and it works now.  I'll test the "bad" one to see if it is actually bad.
Thanks.
Current
Previous
- 1978 Honda CB550K
- 1972 Honda CB450
