Author Topic: interesting fork leak  (Read 853 times)
Offline ben.cb500
« on: July 20, 2011, 07:38:50 PM »
I do believe my newly assembled fork is leaking from one of the axle bolts...possible?
Can they be pulled out and cause a leak, if yes can they be re tightened or thread locked sealed?
Re: interesting fork leak
« Reply #1 on: July 20, 2011, 07:48:21 PM »
There should be a copper crush washer under the head on the 8mm allen bolt that fastens the damper rod. If it is missing or damaged that will be the cause of your leak.
Offline ben.cb500
« Reply #2 on: July 20, 2011, 08:16:00 PM »
Replaced those, as was suspected originally. Not wet but this one bolt is. Wondering if can be r&r d with some sealant?
« Reply #3 on: July 20, 2011, 08:21:38 PM »
Check the drain screws.
Offline CycleRanger
  • No comment about being an
« Reply #4 on: July 20, 2011, 08:23:10 PM »
Yeah, blue loctite is recommended for those bolts.
Offline mjstone
  • I'm definitly not a
« Reply #5 on: July 20, 2011, 08:24:47 PM »
Are you sure its not the drain bolt that is actually leaking?  That's what happened to mine.  It looked like it was coming from the axle cap stud, but was just running down to it from the drain bolt and collecting there.  I bought new copper crush washers for both the allen bolt and the drain bolt.  Replaced both.
MJ
1972 CB500Four (Honda)
1973 CB500Four (Oliver)
