Author Topic: CB750 exhaust collar question  (Read 4012 times)
Offline OrganDonor
    • My other hobby...
« on: July 23, 2011, 01:05:44 PM »
I've recently bought a 76 750 F that has a 4 into 4 original exhaust.  The PO had taken everything (and I mean everything) apart and I got a truckbed-o-parts which was amazingly complete but was lacking the collars to connect the exhaust to the engine.  This bike doesn't have studs normally associated with the exhaust ports, and I assume it uses the clamp style collars?  I've never dealt with these before.
Is there simply a seal that works with the clamp to connect the exhaust, or does it somehow use the half-rings used on the stud-style collars?  The manual only shows a diagram for the stud-mounted collars, and I'm clueless as to the parts I need to get these connected.
77 CB500K
80 CB650 Custom
76 CB750K
Offline RustyJC
Re: CB750 exhaust collar question
« Reply #1 on: July 23, 2011, 02:49:21 PM »
My 1971 750K1 has stub pipes protruding from the cylinder head that the individual exhaust pipes slip over.  These are then clamped down by the clamp-style collars.  No seals or anything else are used.
Rusty
1971 CB750K1 (original owner)
2007 BMW K1200GT
Offline madmtnmotors
  • When did I get to be a
  • Sunny Central Florida
« Reply #2 on: July 23, 2011, 04:21:42 PM »
The stock exhaust on my 76 CB750F is a 4 into 1.
TAMTF...
Wilbur
Projects:
Sent from my Tandy TRS-80!
« Reply #3 on: July 23, 2011, 08:32:50 PM »
madmtn, is yours studs or ring clamp?
 Not sure what it should have, sometimes th  they get changed to fit the other style because they happen upon a set of pipes.
 Do you have the 2 studs, or the spigots (tubes) on the head ?
Offline Kickstart
« Reply #4 on: July 23, 2011, 11:53:45 PM »
The 75/76 CB750F's have studs sticking out - just like the other SOHC CB750's.  In addition to the finned clamp/fitting, there are two half round collars, and one copper gasket - fastening/sealing each header pipe to the head.
Also, as madmtnmotors pointed out, stock on the F's (supersport) was 4-into-1.
I'm not familiar with aftermarket exhaust mounting, so I'm not sure how it would work with what you have... sorry
- Chris
75' CB750F Orange flake (rider)
75' CB750F Blue (Project)
75' CB750F Painted black (Project)
No Reserve Racing #171 AHRMA
Offline RustyJC
« Reply #5 on: July 24, 2011, 02:01:52 AM »
Hmmm.....no studs on a 1971 CB750K1.  Just stub pipes.  I'm not sure what year the changeover was made, but they're not all the same.
Rusty
2007 BMW K1200GT
« Reply #6 on: July 24, 2011, 06:06:08 AM »
Mine uses two studs per pipe to mount the pipe to the head as shown on the attached image.
TAMTF...
Wilbur
Projects:
« Reply #7 on: July 24, 2011, 08:09:33 AM »
The studs can be put into a k head replacing the screws that held the exhuast spigot.Good way to mount up aftermarker 4-1 exhaust systems.
« Reply #8 on: July 24, 2011, 08:12:49 AM »
All models switched to the 2 studs in 77 and 78.
 I was not sure about the first 2 years of F's. which has been confirmed.
 Now we only got to find out about the A , I think they had studs.
Offline Kickstart
« Reply #9 on: July 24, 2011, 10:18:36 AM »
Rusty
Oh... thanks for the correction.  I made an assumption that this was standard for all the bikes.  :-[
so, yeah, I knew better than to assume  Benny Hill tells us not to "assume"
- Chris
