Ok, I am quite used to my modern bikes now, and I'm not sure if my clutch is out of adjustment, needs new plates, or is a typical.
It's sort of a "light switch" on/off clutch. Grabs ok and I haven't detected any slippage once engaged, but requires a very fine manipulation to make it take up smoothly, probably the last 1/4 inch of lever travel.
Thoughts.
![Undecided :-\](http://forums.sohc4.net/Smileys/default/undecided.gif)
