Author Topic: electrical question about LED marker lights  (Read 1026 times)
Offline KRONUS0100
  • MAD MATT THE MANIAC
« on: July 28, 2011, 06:46:08 PM »
1976 CB750F
i have rewired the whole bike, utilizing relays for the hi beams, the low beams, the horn, and fog lights not yet hooked up.
fog lights will be LED as well
question concerns my front marker lights on my windjammer
my dash lights, markers, and main headlight feed are wired thru a toggle switch.
dash lights are super bright blue led's, standard windjammer 7 sealed beam headlight, and super bright white LED marker lights (same bulb as dash lights)
my marker lights dont come on.  they only flash once (like a power surge) when i flip OFF the headlight toggle.........all these lights are wired thru the toggle
  question is.......AM i misunderstanding something here?  do these marker lights need a seperate 12v feed?  the markers are separate from the turn signals
my turn signal bulbs and my tail/brake light bulbs are ordered....and yes I know I need electronic flasher for the turn signals.
thanks in advance.  MATT
MATT
Offline KRONUS0100
Re: electrical question about LED marker lights
« Reply #1 on: July 28, 2011, 08:23:13 PM »
i may have answered my own question................mebb the headlight is consuming to much power for all the leds to work properly.
when i get the led fog light bulbs, i will put the dash and marker led's on the new toggle for the fogs, that way they and the headlight  are on separate circuits.
the flash could be the power from the headlights voltage/amperage  spiking when i flip them off.
MATT
Offline kslrr
  • There is always a Blaster when there is a
  • Raising her up right!
« Reply #2 on: July 29, 2011, 08:24:42 PM »
does this happen only when the engine is not running?  When it is running? or both?
Now  1972 CB350FX (experimental v2.0)
        1981 CB650c Custom with '79 engine (wifes)
        1981 CB650 engine
        2004 HD XL883C Custom
        1977 Yamaha XS750D (in progress)
Then 1972 CL175
        1964 Yamaha YGS-1T
No ride is a Bad ride
Offline KRONUS0100
« Reply #3 on: July 30, 2011, 08:02:07 AM »
happens motor running and not running
did a jumper wire test on just the markers and they work that way, so I think i need to pull em off the headlight circuit.
MATT
Offline KRONUS0100
« Reply #4 on: July 30, 2011, 10:20:23 AM »
oh I AM A DUMBASS!!!!!    i  forgot that the incandescent bulbs dont really cae about polarity, and the LED's do.   I had the sockets wired backwards!!!
D'OH!!!!!!!!!.
MATT
Offline kslrr
« Reply #5 on: July 30, 2011, 10:24:57 AM »
There you go, glad to hear you figured it out.
        1981 CB650 engine
Then 1972 CL175
        1964 Yamaha YGS-1T
Offline skamagedon
  • Mad Scientist-Gearhead
  • My other car is a motorcycle
    • Arcade and pinball repair
« Reply #6 on: July 31, 2011, 09:19:01 AM »
details for the win!
1976 CB550 mutt "Tiger Pain"
(stock carb setup, unifilter, 4-2 baffled)
1976 CB360T "Resto Wifebike...wink wink"
Hot glue is your friend
