Author Topic: Question about coils  (Read 712 times)
Offline zackblack
  • Give my creation... Life!
« on: July 29, 2011, 01:31:12 PM »
Ok so my coil wires were bad so I used the trick found here on the forum to replace them - everything good so far!
Here comes the issue -
I think i have the coil wires marked for the proper plugs but I just want to triple check.  Attached is a picture I drew of my coils (it's what they look like in my hand - not on the bike).  The wires are colour coded and the plug wires are labeled as to what I think is the proper order.
Can somebody go out and have a look at their coils and triple check this for me?  Or can somebody steer me in the proper direction as to where I can find the info out for myself?
Thanks.
:) If I ask a question and forget to post model and year my bike is a '72 CB500 :)
kaniktshaq moritlkatsio atsuniartoq: Umingmaktormiut dialect.
"Observe the snow. It fornicates."
bollingball
Re: Question about coils
« Reply #1 on: July 29, 2011, 01:52:52 PM »
zack Yes you have it correct.
Look in your service manual under ignition
         Ken
« Last Edit: July 29, 2011, 01:55:28 PM by bollingball »
Offline zackblack
« Reply #2 on: July 29, 2011, 09:35:53 PM »
Thanks for the 411.
The manual was how I was "sorta" sure that I had the wires correct but the manual isn't really 100% black-n-white as to what goes where so I made this post to be triple sure.
Just one more question that I want to be "triple" sure on:
The plugs are numbered 1 2 3 4 from left to right correct?
Offline Spanner 1
« Reply #3 on: July 29, 2011, 09:46:52 PM »
Yep.
Offline Spanner 1
« Reply #4 on: July 29, 2011, 09:48:28 PM »
Why did you think your coils were bad?.... just wondered.....
Offline zackblack
« Reply #5 on: July 30, 2011, 01:07:48 PM »
My wires were mushy inside (the middle insulation was tarry mush) and I wasn't getting a good reading with my meter on them so they needed to be replaced.
I preferred the $8.00 wire replacement over the $300.00 coil replacement  ;D
