Author Topic: 750 F cam  (Read 2402 times)
Offline boediddly
750 F cam
« on: July 31, 2011, 07:50:25 AM »
Sweet! just scored a free cam from 78 f and a chrome valve cover. Already have carbs from a 75 f , ported, cut slides,,velocity stacks and a cycle x ignition. I just dont remember if you can get the valve cover off without taking the engine out  . I think I can but I havent owned a cb in 10 years or so so i thought id ask the pros?
Offline kmb69
Re: 750 F cam
« Reply #1 on: July 31, 2011, 08:09:06 AM »
Engine has to come out for a stock K or F frame.
Re: 750 F cam
« Reply #2 on: July 31, 2011, 08:24:23 AM »
You're good to go if it's an A
Offline boediddly
Re: 750 F cam
« Reply #3 on: July 31, 2011, 09:13:36 AM »
Cam is already out of the f engine and going into an A with the engine still in the frame. Love my automatic!
Offline tomsweb1
  • '78 CB750A
  • '78 CB750A
Re: 750 F cam
« Reply #4 on: August 01, 2011, 09:03:16 PM »
Let us know how it goes! Take some pics and vids if you can!
Present: 1978 CB750A, 1978 CB400A, 1983 Nighthawk 550, 1984 CM250C
Past: 1977 XL100, 1982 KZ1300
Offline Danno
Re: 750 F cam
« Reply #5 on: August 06, 2011, 09:55:02 PM »
just a warning honda also lowered the compression ratio on the 750A to promote driveability and if you can't get that cam to Idle low enough you will be fighting the engine every time you stop the 750A was a major engineering triumph of the day and it is full of engineering compromises because it is an automatic with a torque converter
some of these compromises included lowering the torque of the engine so they could make the converter small enough to fit on a bike another would be the fact that it is a wet sump not a dry sump
I am not saying don't do it I am saying you will have to work around these issues  I would advise a cam that you can make idle low enough that the bike does not want to run away from you when stopped and i would highly advise an oil cooler that will work with the bike so you don't kill the converter also remember that converter was not made for increased horse power so lighten the bike as much as you can hopefully that will save it
just some things to think about on your way
