Author Topic: 750A Carb  (Read 754 times)
Offline 77 CB750A
750A Carb
« on: August 02, 2011, 08:54:36 AM »
I have a 77 750A with original carbs but I like the look of the older carbs and want to swap out. Does anyone know if the early 70's k carbs will bolt on to 77 A with out any modification?
KingCustomCycles.com
Re: 750A Carb
« Reply #1 on: August 02, 2011, 08:57:12 AM »
Will not, throat diameter is different
Offline raymond10078
  • Just learnin' as I go . . . .
Re: 750A Carb
« Reply #2 on: August 02, 2011, 10:07:38 AM »
They will if you also replace the head-to-carb "rubbers".
1978 CB750A (upgrading very, very slowly)
Past bikes - Honda: SL350, CX650C, CB900C, CB1000C, CM450A; Kawasaki: several 1972 750 H2's; Suzuki: TC90J.
Bikes I want: CX650ED, a mid-sized japanese V-twin with ABS.
