Author Topic: 72 CL350 kill switch  (Read 1984 times)
Offline SomnoSpeed
  • 1972 CL350 Scrambler
« on: August 02, 2011, 12:55:10 PM »
The kill switch does not work on my bike. Any ideas where I should start first? Diagnosis and treatment. Admittedly I don't know #$%* about fixing anything so be easy on me.
Thanks!
Just bought my first bike and am about as f#$%ing bad at mechanics as a fella can get.
Offline MoMo
  • Ride like you're invisible
Re: 72 CL350 kill switch
« Reply #1 on: August 02, 2011, 01:10:26 PM »
Do you mean the bike runs but the kill switch will not turn it off?...Larry
Offline SomnoSpeed
« Reply #2 on: August 02, 2011, 07:42:48 PM »
That is exactly right. I'm thinking that if my idle gets stuck (again) that it might not be pretty.
Offline tbpmusic
« Reply #3 on: August 02, 2011, 08:26:20 PM »
Assuming you're stock:
Your right handlebar switch has a number of wires. Each of the several black wires going in is 12 volts after the key switch - one of them goes through the kill switch and comes out as black/white.
The black/white then feeds the coils/points.......
Bill Lane
Offline MoMo
« Reply #4 on: August 03, 2011, 06:24:19 AM »
You probably need to disassemble the switch and replace the knob.  There is an inner selector that moves from on to off as the switch is rotated-it frequently breaks, I just had to replace two within the past couple weeks.  Not all that difficult.  Or you could replace the entire switch or wire in your own kill switch-  as pointed out by thpmusic 12v black in and 12v black/white out to the coils...Larry
