Author Topic: Swing arm bolt  (Read 999 times)
Offline Mcwilliams570
Swing arm bolt
« on: August 02, 2011, 01:23:24 PM »
Hello all went out for a few minutes before I have to get some sleep (been working overnights) :( and got the shocks off then started on the swing arm. I got the nut off on the right side when I turn the nut on the left side the whole bolt turns. I did a quick search and saw some stuff on bushing/seals but not how to get it out. When I wake up or get home in the morning will look at the manual and search some more. But if all I got to do is wack it on the right hand side to get it to come out let me know or if I am missing something . Figure I would put a nut on it so I can use a hammer on it without damaging it.
Thanks time for some zzzzz.
My CB550 project http://forums.sohc4.net/index.php?topic=101182.0
Project UFB Cb550 http://forums.sohc4.net/index.php?topic=112143.0
Like a 10 dollar hooker on Friday night its going to be ridden.
1974 cb550
1975 cb550
2005 vmax
2009 vmax-sold
1981 gl500i
KingCustomCycles.com
Re: Swing arm bolt
« Reply #1 on: August 02, 2011, 01:26:19 PM »
I like a wood dowel for any whacking to be done. Should slide right out with some persuasion.
Offline Duke McDukiedook
  • Space Force 6 Star General
Re: Swing arm bolt
« Reply #2 on: August 02, 2011, 01:56:33 PM »
What year and model of bike?
Offline Johnie
Re: Swing arm bolt
« Reply #3 on: August 02, 2011, 02:33:04 PM »
Just did my K1 and had Hondaman do the bushings for me. The bolt on the right seems to stay with the shaft. If worse comes to worse you can use that bolt to unscrew the shaft without damage. I unscrewed it a ways to loosen it up inside and then used a rubber mallet and it came out fine. Don't want to mess up those threads.
1970 CB750K0 - Candy Ruby Red
1976 GL1000 Sulphur Yellow
Oshkosh, WI  USA
Re: Swing arm bolt
« Reply #4 on: August 02, 2011, 04:25:52 PM »
Thanks for the responses , its a 74 550 When I get home in the morning will take a look at it when I am a bit more awake :)
1974 cb550
1975 cb550
2005 vmax
2009 vmax-sold
1981 gl500i
Offline SohRon
Re: Swing arm bolt
« Reply #5 on: August 02, 2011, 05:05:37 PM »
Here's an eploded view of what you're dealing with..
+1
« Last Edit: August 02, 2011, 06:28:28 PM by SohRon »
Re: Swing arm bolt
« Reply #6 on: August 02, 2011, 05:20:55 PM »
You can get brass punch at Horror Freight, works better than wood.
Re: Swing arm bolt
« Reply #7 on: August 02, 2011, 05:25:57 PM »
Thanks for the picture much appreciated and it just so happens I am a Manager at HFT :) Will pick one up when I go in tonight.
Thanks again
1974 cb550
1975 cb550
2005 vmax
2009 vmax-sold
1981 gl500i
Re: Swing arm bolt
« Reply #8 on: August 02, 2011, 06:17:07 PM »
Thanks again
Oops!  No offense intended:)
