Timing isn't really affected by engine temp. However, they usually idle better when warmed up.
If the base plate doesn't fit in the capture posts of the engine block tightly, then the whole plate will move in every direction when the hold down screws are loosened, as the point springs and cam push things around while running.
In the FAQ, you will find a shim procedure to keep the plate stable during timing.
