Author Topic: front signal options (cb550f)  (Read 2245 times)
bluayeddvl
« on: May 03, 2006, 11:14:48 AM »
i did a search and nothing turned up that relates to this bike.
i have a 1975 cb550f supersport that i am desparately trying to find front signals for.
in the event i can not find the stock units, what options do i have that will still reasonable on a stock bike?  ie:  what other bikes would have had something the same or very very similar?
or should i just scrap the idea of original winkers and go for matching front & rear in something new?  but again, what would look reasonable?
certainly there must be some people out there that have done this with acceptable results.
much thanks in advance.
Offline Paul
Re: front signal options (cb550f)
« Reply #1 on: May 03, 2006, 12:43:49 PM »
Certainly Dave Silver in the UK does aftermarket ones ...cheap
www.davidsilverspares or something,
I made the stems from stainless pipe 'because I was sick of spending money on principal.
polished, threadded one end, through the ears / shell and bolt after a rubber washer on the inside (I also bent a tab on a steel washet to stop them rotating.
They are the same as the 500, not sure about the rest 750's etc.
Paul.
It hurts to admit when you've made mistakes, But when the're big enough, the pain only lasts a second
Offline ProTeal55
  • Est1968.com
    • Joe's Barbershop Chicago
« Reply #2 on: May 03, 2006, 12:45:58 PM »
http://HTTP://WWW.CRC2ONLINECATALOG.COM
In ther "Chopper" catalog, they have some smaller units that wouldnt look bad on a CB.
Any light will work, all on how you wire it up !
Offline fishtoft
« Reply #3 on: May 03, 2006, 01:06:00 PM »
You could try www.wemoto.com in the U.K
Offline egar
« Reply #4 on: May 03, 2006, 02:36:43 PM »
Dennis Kirk has stock signals
sohc4
'04 ST1300, '70 cb750KO
Offline Chris Liston
« Reply #5 on: May 03, 2006, 03:11:04 PM »
Depending on whether or not you keep the stock headlight mount you could do this.  This is what I had going on.  I mounted the blinkers to the headlight and tightened up from inside the shell.  Got the lights on ebay.  There aluminum and very nice..
You could also I guess use them with the stock headlight ears/mounts but you'ld have to cut the threaded bung off the mounts..
« Last Edit: May 03, 2006, 03:13:31 PM by Chris Liston »
1976 CB550F Cafe in progress
dafrpa
« Reply #6 on: May 03, 2006, 04:04:32 PM »
Hey there - CB750RR from Ott-MOTO forum here -- I forgot to mention partsnmore.com as a possible source. There is no listing for 550, but the big round signals listed for the 750 should work.
There's a $50 US minimum order though, with free shipping....but lots of extras in the accessories/tools section to get up to the minimum.
bluayeddvl
« Reply #7 on: May 04, 2006, 12:08:57 PM »
thanks all for your help on this.
everyone's input is truly appreciated.
dafrpa... cheers.  will check into that.
chris liston... yeah, been sussing those too.
egar... thx much.
fishtoft... thx for that, but i know for sure the shipping would be a bear.
ProTeal55... thx.  will check that.  yeah, any light will work, but i'd rather not make it too fugly just yet.  that'll come tho.
Paul... TA for that.  but again, shipping from the UK is a bugger.  your ideas are nice tho.  *gears are turning*
Offline ProTeal55
  • Est1968.com
« Reply #8 on: May 04, 2006, 12:22:51 PM »
"Fugly" and "Custom" are two very different worlds..... ;D
Offline dusterdude
« Reply #9 on: May 04, 2006, 01:34:12 PM »
i dont know joe,occ seems to do a good job of intertwining the two.
mark
1972 k1 750
1949 fl panhead
1 1/2 gl1100 goldwings
1998 cbr600 f3
beachpeople
« Reply #10 on: May 04, 2006, 04:47:32 PM »
Try this place out for ideas... http://www.customdynamics.com/motorcycle_lights.htm .
bluayeddvl
« Reply #11 on: May 05, 2006, 06:31:30 AM »
oh yeah... i forgot completely about these guys.  thx much.
bluayeddvl
« Reply #12 on: May 05, 2006, 06:35:58 AM »
well said!!!  ... *coffee out my nose*
