Author Topic: 750A engine swap  (Read 1759 times)
Offline 77 CB750A
750A engine swap
« on: August 06, 2011, 12:44:45 PM »
Does anyone know if swaping out the 750a motor to a 750k motor is a bolt on or does the mounting differ on the frame between the models?
Offline Danno
Re: 750A engine swap
« Reply #1 on: August 06, 2011, 09:34:07 PM »
Front bolts are the same but the rear are slightly different because of the torque converter I do not know if it is the same for the alternator side as well  I was told by a friend when i talked about doing the same thing that the frame would have to be modified but i believe he was refering to the bolt gussets
