Author Topic: Turn Signal  (Read 1471 times)
Offline MADCB400F
  • My 74 CB750
Turn Signal
« on: August 07, 2011, 02:26:33 PM »
Hi all, cannot find an answer, I put LED turn signals and LED flasher on my 1974 CB750. How do I get the idiot light for the turn signal indicator to work now. Thank you.
Offline Bodi
Re: Turn Signal
« Reply #1 on: August 07, 2011, 02:47:44 PM »
This is an odd circuit that lights the indicator bulb through the not-on signal bulb. Tthe indictor is wired across the power wires to the signal lamps, getting the stock bulb to work with LED signals will be a trick. Getting an LED indicator to work... likewise I think. Probably powering a small relay through a diode from each signal lamp wire then powering the indicator via the relay contact is the only way.
Offline MoMo
  • Ride like you're invisible
Re: Turn Signal
« Reply #2 on: August 07, 2011, 02:51:30 PM »
I used led signals and an electronic flasher from the auto parts store and my gauge indicator works...Larry
