Author Topic: What's wrong in this pic? Solved!  (Read 2238 times)
Offline Frostyboy
  • Retired: Never was an
  • Circa 1951
« on: August 08, 2011, 03:26:41 AM »
« Last Edit: August 08, 2011, 04:49:40 AM by Frostyboy »
Last year I joined a support group for procrastinators.
We haven't met yet.
[CB550F1]
    • http://forums.sohc4.net/index.php?PHPSESSID=g9fu847q9jlhtljqgrluts02n0&/topic,60973.0.html
Re: What's wrong in this pic?
« Reply #1 on: August 08, 2011, 03:49:03 AM »
its not my bike..thats vrong 8)...are the spacers mont vrong??looks good for me
Offline Frostyboy
  • Circa 1951
« Reply #2 on: August 08, 2011, 03:52:40 AM »
No not that. Keep looking.  ;)
We haven't met yet.
[CB550F1]
Offline Blitzburgh207
« Reply #3 on: August 08, 2011, 04:08:02 AM »
Chain guard rubbing? whats that wrapped around the swingarm by the shock mount? License plate? lol  ::) Im not sure really just guessing...
1978 CB750 K8
bollingball
« Reply #4 on: August 08, 2011, 04:11:29 AM »
Axel bolt on backwards. Not sure about the tire.
« Reply #5 on: August 08, 2011, 04:14:43 AM »
Shock to swingarm bolts are to long.
Offline Raul CB750K1
« Reply #6 on: August 08, 2011, 04:18:03 AM »
I don't think there is a "right way" to insert the rear axle. It just clamps the wheel in the swingarm and, as long as the spacers are not swapped, there is no difference in where do you insert the axle from.
Furthermore, he would have a hard time removing and inserting the axle from the other side, because of the exhaust.
Offline CBGhia
« Reply #7 on: August 08, 2011, 04:18:24 AM »
The kickstand was put down on soft grass and the bike will fall over in 3...2....1....ouch!?
Offline Syscrush
  • Sold. :(
« Reply #8 on: August 08, 2011, 04:24:28 AM »
I don't know, but to me that tire looks like it's on backwards.  Looks like the tread would channel water into the center of the tread, not away from it.
Offline madmtnmotors
  • When did I get to be a
  • Sunny Central Florida
« Reply #9 on: August 08, 2011, 04:30:31 AM »
Centerstand looks to be quite high. Is it missing a stop bracket and rubbing the chain and/or brake rod?
TAMTF...
Wilbur
Projects:
Sent from my Tandy TRS-80!
Offline kmb69
« Reply #10 on: August 08, 2011, 04:35:59 AM »
Centerstand is missing the Step Bar.
Hinomaru
« Reply #11 on: August 08, 2011, 04:37:54 AM »
The shock springs have different spacing between the coils.
Offline m in sc
« Reply #12 on: August 08, 2011, 04:42:31 AM »
did the dust seal on the LH axle fall out and resting on the spacer? also hard to tell but looks like the shock is pushing the chainguard over.
Offline Frostyboy
  • Circa 1951
« Reply #13 on: August 08, 2011, 04:49:04 AM »
BINGO!
You got it. It probably doesn't make the world of difference, but I had the right hand spring upside down.
It's fixed now.
;D ;D ;D
They are a bit long, but I thought if I cut 'em the end might go rusty. They're plated.
Yep that too, what a pain in the a$$ it is too. I've got it somewhere. Will have to weld it back on.  >:(
« Last Edit: August 08, 2011, 04:54:56 AM by Frostyboy »
We haven't met yet.
[CB550F1]
Re: What's wrong in this pic? Solved!
« Reply #14 on: August 08, 2011, 04:56:17 AM »
Good eye Hinomaru
Offline Gordon
  • 750K1, 550K2
« Reply #15 on: August 08, 2011, 09:12:11 AM »
No cotter pin in the axle nut.
Offline Nezhac
« Reply #16 on: August 08, 2011, 09:23:33 AM »
no hot babe wrapped around the bike, did you shoo them all away for a pic?
Honda CB 350 F
Offline Frostyboy
  • Circa 1951
« Reply #17 on: August 09, 2011, 08:20:36 PM »
That's the bracket for the chain guard.
Correct.  ;)
The arrow is facing the right way.
Oh yes there is.  ;)
I wish.  :(
We haven't met yet.
[CB550F1]
Offline Syscrush
  • Sold. :(
« Reply #18 on: August 10, 2011, 04:44:36 AM »
Then forget I said anything. :)
