The argus is almost certainly self powered with its own internal battery (if it truly drains nothing from the host battery.)
I wonder how long that internal battery lasts? I speculate the same as a watch battery. Can you access that for replacement?
If those leads attach directly to the battery posts, it certainly has the capability to be accurate. But, I haven't seen tests, or specs for that.
I'm either lazy, or too involved in house projects.
Maybe I am old school or just old but I like numbers either LED at night LCD with bright back light or analog.
If you were truly old school, you wouldn't be happy unless there was a D'Arsonval movement swinging a needle on a mirrored scale.
jk
