Author Topic: brake bleeding questions.. with bleeder  (Read 642 times)
Offline the technological J
  • deliciouso!
« on: August 10, 2011, 10:47:36 PM »
has any one used a bleeder like this? it has a guage  that is supposed to be in inches of mercury.. but i dont really understand it i just pump it up and open the bleeder.. is there more to it than that...
oh heres the link to it
http://www.cyclegear.com/spgm.cfm?L1=&L2=&L3=&L4=&item=USI_990083
it worked well for  a couple master cylinders that didnt push the fluid to pressure but i still feel like somethings off
94 ST1100..Gone
72 750 K2 Stay tuned!
bollingball
Re: brake bleeding questions.. with bleeder
« Reply #1 on: August 11, 2011, 04:51:02 AM »
tech just look at the gauge before it gets to zero turn the bleeder off if not you could let air back into the system.
Online Johnie
« Reply #2 on: August 11, 2011, 05:32:07 AM »
That is just a basic vaccum system to suck the air out of the lines. As you bleed the brakes you want to be sure you create a vaccum and that is what the gauge is for. I have the MityVac which is the same deal. They work nice especially after a master cylinder rebuild if you have trouble getting the air out. Have the bleeder closed, then pump the handle to 5 or 10 is what mine says, then slowly open the bleeder and watch the bubbles come out. If you have a ton of small bubbles that means air is getting in past the bleeder threads. If that happens you will need to put a little teflon tape on the threads which works for me.
« Last Edit: August 11, 2011, 05:34:02 AM by Johnie »
1970 CB750K0 - Candy Ruby Red
1976 GL1000 Sulphur Yellow
Oshkosh, WI  USA
