Author Topic: Having trouble getting the two cam sprockets bolts off 74 cb550  (Read 490 times)
Offline Mcwilliams570
Hello all I am trying to get the cam sprocket bolts off and am having trouble when I start to put torque on them to loosen  the sprocket and chain rotate. Do I need to put the bike in gear?
It also looks like one of the cam lobes is pitted and rough picture included not the best will try to get a better one later on. I figure it will be a good excuse to put a 650 cam in :)
Well off to degrease the frame at the carwash any help or suggestion would be much appreciated.
Matt
My CB550 project http://forums.sohc4.net/index.php?topic=101182.0
Project UFB Cb550 http://forums.sohc4.net/index.php?topic=112143.0
Like a 10 dollar hooker on Friday night its going to be ridden.
1974 cb550
1975 cb550
2005 vmax
2009 vmax-sold
1981 gl500i
Offline Duanob
  • Bold Timer
  • Gotcha!
Re: Having trouble getting the two cam sprockets bolts off 74 cb550
« Reply #1 on: August 14, 2011, 09:18:34 AM »
"Do I need to put the bike in gear?"
I think you answered your own question. Use a wire through the cam chain so it doesnt fall down into the cases. Don't forget to change out those rubber pucks. When you put the valve cover back on don't forget the rubber band trick or you will bend valve stems.
1974 CB360T
1976 CB550K2 Resurrected
1976 CB550F2 Barn Find
1979 CX500 VG "HONDA-GUZZI"
2007 Moto Guzzi Breva 750ie
2015 BMW F700GS
Another 1976 CB550K Cafe?
  __o
_- \_<,
