Author Topic: Well, sh!t....broke a bolt on the clutch center  (Read 2200 times)
Offline Scott S
« on: August 13, 2011, 09:51:57 AM »
 I was changing the oil/filter on my CB500 and taking the opportunity to replace a broken pushrod.
 Had the oil drained, new filter in and old, broken push rod out. I checked the manual for torque specs on the clutch center and it said 29-33 lbs. Seemed liked a lot to me, but OK. Snapped a bolt off in one of the posts.
 I'm removing the clutch basket now to see if I can save it, but is that right on the torque specs? Seems awful high for a bolt with a 10mm head.
 I'm thinking of replacing all four of the bolts. What grade should I get?
'71 CB500 K0
'17 Triumph Street Scrambler
'81 Yamaha XS650
Offline Scott S
Re: Well, sh!t....broke a bolt on the clutch center
« Reply #1 on: August 13, 2011, 11:00:56 AM »
 Tragedy averted. My local shop was able to get the broken bolt out easily and ran a tap through the clutch center. Pep Boys had the correct bolts in "class 8.8" for $1.29/4.
 I'm gonna grab a slice of pizza and an RC cola and take a break. Hope to have it back together in a couple of hours.
'71 CB500 K0
'81 Yamaha XS650
Offline camelman
  • Man... Myth... Legend
« Reply #2 on: August 13, 2011, 01:12:33 PM »
That torque spec seems high. Is it inch pounds?
1972 350f rider: sold
1972 350f/466f cafe: for sale
1977 CB400f cafe:sold
1975 CB400f rider: sold
Offline mrrch
« Reply #3 on: August 13, 2011, 02:10:21 PM »
That sounds like the torque for the center nut not the small bolts.
my build
Offline camelman
« Reply #4 on: August 13, 2011, 03:21:47 PM »
Agreed!  Those 10 mm should only be 7 ft-lb or so.
Offline madmtnmotors
  • When did I get to be a
  • Sunny Central Florida
« Reply #5 on: August 13, 2011, 03:22:47 PM »
+1
I believe the torque for that would have been "in/lb" not "ft/lb".
12 in/lb=1 ft/lb
TAMTF...
Wilbur
Projects:
Sent from my Tandy TRS-80!
Offline Scott S
« Reply #6 on: August 13, 2011, 04:36:58 PM »
 There is no center bolt on the 500. The basket is help on with a snap ring.
 The local shop also suggested that maybe it was in/lbs., and I tend to agree now. But, the aftermarket manual I have says ft/lbs. In retrospect, it MUST be a misprint. Maybe this will help someone else from making the same mistake I did.
'71 CB500 K0
'81 Yamaha XS650
« Reply #7 on: August 13, 2011, 08:03:33 PM »
I keep a copy of Pocket Ref (http://www.pocketref.com/) in the garage. Packed with all kinds of information, including torque specs for bolts by diameter and thread pitch. Has helped me when torque info seemed incorrect, or missing altogether.
TAMTF...
Wilbur
Projects:
