Author Topic: Three bad spark plugs?  (Read 646 times)
Offline tango911
« on: August 15, 2011, 04:55:52 AM »
A friend brought his friends CB500 to me to trouble shoot.   They had rebuilt the carbs but were leaking like crazy and when they put it back on, it ran for a bit and then never started again. So i said id take a look and see what it might be.  I pulled the carbs and adjusted the floats and re installed,  1 carb still leaking but should be an easy fix so i left it on for now.   Started trouble shooting the no spark issue.  Found that one of the points wires was loose, once I plugged it back in i started looking at the timing and power to the coils, points gap was also too big (corrected that). Hooked up the timing light, finding that only cylinder 4 was getting juice.   I was using my timing light to check each wire for power. HOWEVER i didnt think to go ahead and throw new plugs in.  I finally pulled the other 3 plugs out and they would not spark at all when grounded to the engine. SURELY not all 3 are bad,  once i got a new plug in they all had spark.
I have not checked the caps yet, but ive never seen 3 plugs go bad all at one time.
« Last Edit: August 15, 2011, 04:57:53 AM by tango911 »
CURRENT STABLE:
1969 Honda Dream 305 (black)
1974 Mach III kawi 500 smoker
K2 (project)
K2 Original fixer up
K0 original fixer up
2006 CRF250R
KingCustomCycles.com
Re: Three bad spark plugs?
« Reply #1 on: August 15, 2011, 07:28:56 AM »
"glazing" will ground plugs immediately.  It is a coating from improperly burnt fuel, air, and oil that prevents sparking by insulating the electrodes.
Offline tango911
« Reply #2 on: August 16, 2011, 06:31:53 AM »
so maybe the previous owner put too much lead additive in his fuel?
CURRENT STABLE:
K2 (project)
2006 CRF250R
