Author Topic: CB750 K1 Neutral light comes on in third and forth gear  (Read 1498 times)
Offline mycb750k6
  • "res ipsa loquitur"
  • Rocketman
    • photobucket albums
« on: August 13, 2011, 11:56:51 AM »
My CB750 K1 neutral light will come on and off intermittently while riding. Something loose?
Offline CycleRanger
  • No comment about being an
Re: CB750 K1 Neutral light comes on in third and forth gear
« Reply #3 on: August 14, 2011, 03:49:00 PM »
Well, my first thought would be to check the switch and the wiring.
Offline Spanner 1
« Reply #4 on: August 14, 2011, 07:02:06 PM »
Sorry, can't answer until you tell me which K1 were talking about ? #1,2,3,4   :D :o
Loose 'fork' connector at the N switch on the underside of the lower casing... hey, you know where it is , you have 4 K1's !!!.... and the wire is touching ground (= bulb lights )....... or the switch has loosened a few turns in the casing........
« Last Edit: August 14, 2011, 07:04:01 PM by Spanner 1 »
bollingball
« Reply #5 on: August 14, 2011, 07:13:55 PM »
Have you looked at the sw.? How does the wire connector look is it loose or touching something it should not? Do you have the safety circuit on your bike?
Offline mycb750k6
  • Rocketman
« Reply #6 on: August 15, 2011, 05:33:17 AM »
Got it thanks!  :) Looked there first but the screw was tight and I gave up.  And it was K1-4  ::)  My current project.  I pulled the entire switch and replaced it. Definitely need a new O-ring to keep it from dripping!
Offline Johnie
« Reply #7 on: August 15, 2011, 06:49:18 AM »
I also used just a small tad of anerobic sealer on that O ring. No leaks...
1970 CB750K0 - Candy Ruby Red
1976 GL1000 Sulphur Yellow
Oshkosh, WI  USA
