Author Topic: K1 coil wiring question  (Read 766 times)
jtinker00
« on: August 15, 2011, 07:11:03 PM »
I'm wiring up my coils I made a simplified harness. There are two black wires with white stripes. Are these power wires? I'm nit getting spark and I believe it's from this
bollingball
Re: K1 coil wiring question
« Reply #1 on: August 15, 2011, 07:58:26 PM »
The black with white stripe wire is the 12vdc power coming from the kill Sw. on a stock harness. It should be one wire going to one coil then loops over to the other coil. So they both get power when the kill Sw. is in the run position. Did you put a kill Sw. on your simplified harness?
« Last Edit: August 16, 2011, 05:30:03 AM by bollingball »
