Author Topic: Float bowl drain screws - K0 carbs?  (Read 1443 times)
Offline Magpie
« on: August 15, 2011, 07:32:41 PM »
Hi! On the early K0 carbs the float bowl drain screw has a small slotted head. On another incomplete set I have the drain screws are similar to the K1's, a much larger head, are these correct for later K0 carbs?
Thanks,
Cliff.
Offline 736cc
Re: Float bowl drain screws - K0 carbs?
« Reply #1 on: August 15, 2011, 07:43:49 PM »
nope
Offline Johnie
« Reply #2 on: August 15, 2011, 07:48:21 PM »
Just took a look at my KO & K1 and both are the smaller slotted. The larger ones you are talking about came out in later bikes. My K4 has the larger ones and my guess would be those started around the 72 K2 models but those guys can chip in for sure.
1970 CB750K0 - Candy Ruby Red
1976 GL1000 Sulphur Yellow
Oshkosh, WI  USA
Offline Magpie
« Reply #3 on: August 15, 2011, 08:07:52 PM »
My 7/71 K1 has the larger headed screws and has the origianl carbs. Cliff.
Offline 736cc
« Reply #4 on: August 16, 2011, 04:08:51 AM »
My very late K0 built 6/71 has the little screws
Offline Johnie
« Reply #5 on: August 16, 2011, 05:34:48 AM »
Cliffy...I think it was a case of putting on what was at the factory at the time. My KO is 1/70 and my K1 is 9/70 both with the small.
Oshkosh, WI  USA
Offline Magpie
« Reply #6 on: August 16, 2011, 07:19:00 AM »
Ok, thanks guys!! Cliff.
« Reply #7 on: August 16, 2011, 09:07:51 AM »
 If you cant find them, may be able to make them.
 Rather than risk buggering them up, easier to pop the bowl.. I think..
Offline Magpie
« Reply #8 on: August 16, 2011, 12:52:22 PM »
Hi Frank! Yamiya has them but with shipping they come top $15 each! The float bowls are different for the smaller screws as well. The area at the drain is smaller, about the size of the head of the smaller screws. I guess I'll have to keep an eye for some to pop up. Of course not many people would spot them except for those answering here.
Cliff.
Offline gonzobrian
« Reply #9 on: August 16, 2011, 04:12:39 PM »
Good info.  That means I have three that are correct and one that is not.  As opposed to needing to replace three and keep one, which is my normal luck.   ::)
« Last Edit: August 16, 2011, 04:14:23 PM by gonzobrian »
Offline Magpie
« Reply #10 on: August 22, 2011, 06:41:41 PM »
I should learn to look at my reference books before posing a question!!! There's the answer on pages 34 and 35 (and several more) of John Wyatt's book "Original Honda CB750". The answer is both sizes of screws came on the K0 carbs. My apologies men!
Cliff.
