Author Topic: CR29 "carb fart"  (Read 1635 times)
Offline brandEn
CR29 "carb fart"
« on: August 22, 2011, 01:52:11 AM »
Just wondering why my carbs purge air out the stacks when I turn my key on? I have named this carb fart for technical clarification in the future.
Offline Doctor_D
Re: CR29 "carb fart"
« Reply #1 on: August 22, 2011, 01:37:36 PM »
It's not the carbs, it's the dyna 2000 -- which sparks once when you turn the key.  A little bit of fuel in the cylinders is all it takes to get that "chuff."
Take care,
David
1978 CX500
1971 Norton Commando
Offline voxonda
« Reply #2 on: August 22, 2011, 02:16:58 PM »
My racer is farting too, and it has a Accent electronic ignition.
Cheers, Rob
Offline Doctor_D
« Reply #3 on: August 22, 2011, 02:20:27 PM »
So does my Norton, with a Tri-Spark.  Pretty sure my Boyer MkIII did as well. Must be a charastic of the circuitry.
Take care,
David
1978 CX500
Offline tweakin
  • tear down
« Reply #4 on: August 22, 2011, 04:17:19 PM »
I was going to tell him to stop pouring beans in the tank.... ;D
Offline brandEn
« Reply #5 on: August 22, 2011, 04:40:00 PM »
Doctor D lives! Where the hell you been hiding. We need a build update. That thing gonna be ready for Vashon on Sep 11?
« Reply #6 on: August 22, 2011, 06:10:06 PM »
He has been posting. Dyna3's did the same thing ESPECIALLY if you ran a lot of advance!
Offline Doctor_D
« Reply #7 on: August 22, 2011, 07:36:56 PM »
Vashon is on my list, but it all depends on the work schedule.
As for an update, the punch list is getting shorter.  I need to glass up a rear fender, mount the rear brake reservoir and license plate, wire up the tail and brake lights, and wrap the wiring harness. Tins have finally been pinstriped and are off being clearcoated.  Seat pad needed some small mods to make it fit and will be back shortly.  In short, pretty much done.
Take care,
David
1978 CX500
« Reply #8 on: August 22, 2011, 08:12:25 PM »
Dyna 3's...the same thing....with a lot of advance. Half a revolution!
