Author Topic: How to get the carb bodies silvery again?  (Read 6398 times)
Offline Magpie
« on: August 23, 2011, 09:37:42 AM »
I've soaked carb bodies in Simple Green and had to use paint stripper on another set which darkened the colour up a lot. Is there anything that can be used to get them that lovely stock colour again?
Thanks in advance.
Cliff.
Offline Bowswell
  • CB750K1,CB750 K4,CB350F,CB400t1,meanstreak
Re: How to get the carb bodies silvery again?
« Reply #1 on: August 23, 2011, 09:42:06 AM »
try soda blaster.
Offline xsmooth69x
« Reply #2 on: August 23, 2011, 09:56:08 AM »
i am wondering the same thing. everything is painted nice on the bike, the float bowl and tops are nice and shinny then BAM dull dark gray carbs  >:(
1975 CB550 (FINISHED?!?!?)
KingCustomCycles.com
« Reply #3 on: August 23, 2011, 10:04:22 AM »
Brass wire brush and scotchbrite pads
Offline jessezm
  • '77 cb400f cafe build
  • Always wrenching...
« Reply #4 on: August 23, 2011, 10:21:04 AM »
if you have a decent air compressor you can make your own soda blaster with an air nozzle and a piece of tubing.  I made one and it worked really well on the carbs, they look brand new.  Or you can go King's route and make them look better than new  ;)
I've actually been kicking around the idea of anodizing, cause yeah, I really NEED to spend a bunch more money on my bike.  gah!
Offline xsmooth69x
« Reply #5 on: August 23, 2011, 11:08:26 AM »
dosnt that really scratch up the carbs though? how do you polish it after? there are so many little nooks and crannies
bollingball
« Reply #6 on: August 23, 2011, 11:36:06 AM »
I have had very good results with white diamond metal cleaner/polish . The only thing for those tight spots is a dremel tool buy lots and lots of scotch brite pad and finish with felt pads more time than it is worth to me. Maybe do 1 & 4.
Offline Nitsuj
    • Superbikestore.net
« Reply #7 on: August 23, 2011, 03:03:08 PM »
I soaked mine in a can of gunk carb cleaner from Autozone. They came out nice and silver. YMMV.
Offline CycleRanger
  • No comment about being an
« Reply #8 on: August 23, 2011, 04:30:23 PM »
Offline Bowswell
« Reply #9 on: August 23, 2011, 05:01:30 PM »
check the difference
« Reply #10 on: August 23, 2011, 05:09:10 PM »
i blast soda like this.
Offline cookindaddy
  • I sure love this bike!
« Reply #11 on: August 23, 2011, 05:30:56 PM »
Magpie - Wow - are you ever organized! Good use of the parts box to store the components!
Try soda blasting. I was skeptical until I tried it. Works great. I bought a cheap blasting gun at Princess Auto and a big box of baking soda at the grocery store. Do it outside, the soda goes everywhere. But it works great and no serious abrasion of the parts, just cleans them up to the bare metal.
George with a black 78 CB750K (in Lion's Head, Ontario, Canada)
Offline Magpie
« Reply #12 on: August 23, 2011, 06:18:16 PM »
Looks great and I like going to Princess Auto!  Thanks guys! Cliff.
Offline CycleRanger
« Reply #13 on: August 23, 2011, 06:34:07 PM »
yeah, if you can't do soda blasting that would probably be my second choice.
There are several threads here about building a soda blasting rig on the cheap.
Assuming of course you have access to a decent compressor.
« Last Edit: August 23, 2011, 07:13:55 PM by CycleRanger »
Offline Magpie
« Reply #14 on: August 23, 2011, 06:52:26 PM »
I think the soda blasting will be better than another soak. The soaking caused the carbs to go darker, hopefully the soda blasting will remove the discolouration. Princess Auto's website shows a number of small gravity fed blasters, nothing specific for soda though. I've asked if a couple they have will work with soda but no answer yet.
Cliff.
Offline cookindaddy
« Reply #15 on: August 23, 2011, 07:09:28 PM »
The blasters work with dry powder in a reservoir. Just put in baking soda instead of the harder stuff (sand) that they expect you to want to be using. You won't hurt the blaster or the parts. Easy. It works great.
Offline Johnny5
    • CB350F build thread
« Reply #16 on: August 23, 2011, 07:17:19 PM »
Im looking into soda blasting. I have a 21 gallon 4.7 SCFM @ 90 PSI compressor. Will this be sufficient to blast soda?
www.kerosenecycles.com
1971 CB350
1973 CB350F
2006 Harley Springer Classic
Offline Magpie
« Reply #17 on: August 23, 2011, 07:21:04 PM »
cookindaddy, which one did you buy? Cliff.
Offline cookindaddy
« Reply #18 on: August 24, 2011, 03:56:26 AM »
Hopefully this picture will help you.
It was not expensive, I think $10-20.
I did have to keep shaking it when spraying to get a continuous flow with the soda.
bollingball
« Reply #19 on: August 24, 2011, 06:16:20 AM »
I get the soda at Sam's club or the pool supply store 50 or 100 pound bags a lot cheaper left overs go in the pool if my PH is off ;)
Dave500 I like the plastic jar I'll try that for small parts I have been using a 5 gal. bucket.
« Last Edit: August 24, 2011, 06:19:39 AM by bollingball »
Offline Magpie
« Reply #20 on: August 24, 2011, 08:30:52 AM »
Thanks cookindaddy! The website shows this one with the hopper on top which may save some shaking to keep the flow going. http://www.princessauto.com/workshop/air/sandblasting/sandblasters/8140709-gravity-fed-sandblasting-gun  The closest store to me is across the water in Coquitlam, I'll have to get a friend to make the pilgrimage for me. There's one being being built here at last.
Cliff.
« Last Edit: August 24, 2011, 08:34:12 AM by Magpie »
Offline rbmgf7
  • 2>4
« Reply #21 on: August 24, 2011, 09:58:38 AM »
Aluminum reacts with many chemicals. From personal experience, it will discolor from Simple Green and the Citrus Strip paint stripper. Using Simple Green will also create a white sediment growth which will become hard and crusty if you don't rinse your parts thoroughly. The Citrus Strip will just discolor similar to the Simple Green.
I polished one set of carbs using a Dremel with assorted buffing pads and brass brush with pretty decent results. Definitely time consuming.
Offline Silverback
« Reply #22 on: August 24, 2011, 11:11:02 AM »
I have one of these from Harbor Freight:
http://www.harborfreight.com/21-oz-hopper-gravity-feed-spot-blaster-gun-95793.html
On sale now for $10. I have done several carbs and recently an entire motor with it. Worked great for me. It has a dial on it to regulate media flow which is good for using the finer soda media. HF also has medium and course grade soda($35 for a 50lb bag). Medium would work great for your needs and you'll have lot's left over for all jobs in the future.
Edit: Just noticed your in Canada. No Harbor Freights there. What a shame! The one you linked above is very similar, though.
« Last Edit: August 24, 2011, 11:16:43 AM by Silverback »
Chris
"It's hard to define soul. You get it in art. You get it in music, and occasionally you get it in machinery."
78 CB750F racer
78 CB750F stock
75 CB750K Baby Blue Sold (She was a great bike!)
71 CB750K (rusty rod)
77 cb550F Sold :(  Bought it Back :)
Basket case 73 CB750, 77 CB750F (Building now)
01 Aprilia Falco
76 kz400
96 BMW K1100LT
Offline CycleRanger
« Reply #23 on: August 24, 2011, 11:45:09 AM »
I'm looking into soda blasting. I have a 21 gallon 4.7 SCFM @ 90 PSI compressor. Will this be sufficient to blast soda?
For cleaning small stuff like carb parts that should work ok with the small hand-held blasters they're talking about here but for any bigger projects you're gonna want at least 7-8+ SCFM.
As I mentioned above, there's several good forum threads about soda blasting, compressors, building blasting cabinets, etc.
Offline Cevan
« Reply #24 on: August 24, 2011, 12:00:31 PM »
Soda blasting is the way to go.  I tried it with my regular sand blaster and it worked ok.  But real soda blasters siphon the baking soda.  I then bought the $99 one from Harbor Freight and it works great.  Holds 20 lbs of baking soda.  I've used regular old Arm and Hammer bought at Walmart for something like $1.19 for a 2 lb box.
1972 CB500/4
1974 CT70
