Author Topic: Confused on 750- KO motors  (Read 625 times)
« on: August 24, 2011, 09:40:20 PM »
 I got a few in the shop right now;
 cases 10,***
 lower end #20, ***
 Whole engine #16,***
 Whole engine #44,4**
 Book lists cases same from 7,415 thru 44,8** I looked at e 16K and 20K motors but the $$K is different, probably like K1, I am thinking. Any thoughts on this?.. I suspect more than 1 engine line and when new cases came out some got stamped out of series.
 Heads without front hole; by partsbook looks like these ended @ 26,***, is that what you guys have found?
 Also seeing some difference between KO heads and K2, ie exhaust spigot length.
 Also have a head73 and later marked 300 5 on rear top fin between 2&3 cylinder, is that FO or F1 ?
Re: Confused on 750- KO motors
« Reply #1 on: August 25, 2011, 12:29:42 AM »
I have a F1 engine out of the frame, i will check tomorrow....
