Author Topic: '80 CB650c fine tuning question  (Read 498 times)
Offline ABikeNamedTrouble
« on: August 31, 2011, 05:36:45 PM »
Hey folks,
Well, after a couple months of work, I've finally got my 1980 CB650c running well and have put about a thousand miles behind me without any difficulties that weren't my own fault ;).
One thing has been bugging me:  when I let off the throttle to engine break, the engine jerks and runs roughly instead of a smooth slow down.  I'm also consistently getting around 40-45 mpg instead of the usual(?) 55 mpg.
Any ideas on what could cause this?  I have the mechanical slide (Keihin PD) carbs, and they're well synced.  I haven't noticed any other problems.
Thanks in advance for the help,
- Adam.
- Adam
1980 CB650c Custom
Keihin PD mechanical carbs
Stock air box and 4-4 exhaust
http://forums.sohc4.net/index.php?topic=97504.0
Offline cb650
Re: '80 CB650c fine tuning question
« Reply #1 on: August 31, 2011, 05:51:44 PM »
Air cut off on the carbs would be my first guess.
« Reply #2 on: August 31, 2011, 05:59:30 PM »
I would have thought the same, but the diaphragms are brand new and installed to spec.  I'm definitely new to motorcycle repairs though, so I could have missed something (not sure how though, they're simple devices).
- Adam
1980 CB650c Custom
Offline Zodo
« Reply #3 on: August 31, 2011, 08:51:11 PM »
The air cutoffs have a little tiny air hole to the side when you take the cover off. Make sure that they have their o ring in tact and aren't blocked.
